Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
I was just reprogramming and doing some basic testing when I noticed if I unplugged the usb cable, nothing would work. I got digging and discovered that my oil pan was only getting about 1.0 V! I pulled off the oil pan and noticed that the pwr led is off! The mux led is the only one that is on.
Did I magically fry my board? Any ideas?
I wasn’t poking any wires around or anything that could have shorted it as far as I remember. Just reprogramming and doing some tests.
Stick wiggling is now handled by the new interactive setup mode. After you have compiled and uploaded the code, slide the switch on the IMU to the 0 position and start the Arduino console. Make sure you have the console line endings set to "Carriage Return". Use the 'setup' command to visit the setup menu, and be sure to use the 'factoryreset' command at least once to get your EEPROM updated.
Steve
http://code.google.com/p/ardupilot-mega/wiki/Reversing
