Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
You have not set your Arduino Sketchbook location correctly. If you are using the Sketchbook checked out, or from the zipfile, you must tell Arduino where it is.
We ship a complete Sketchbook because we want you to have all the libraries together and up to date, and it's hard to be sure of this if you have to manually copy them around by yourself.
It looks to me like the compiler can't find any of the files that are in the seperate library folder. The Libraries folder is in the same folder as the ArduPilotMega folder, but it is not obvious to me how the IDE would know to associate these libraries.
We're trying to make this clear to non-programmers, but maybe it's still a little confusing? Maybe I'll spell it out a bit more, like this:
//#define GPS_PROTOCOL GPS_PROTOCOL_MTK // You must uncommment this line by removing the slashes in front of the # and select either the default (GPS_PROTOCOL_MTK) or one of the following other supported GPS modules if you're using one of them instead
