ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
  • As I recall, the user is supposed to have full control of the throttle in stabilize mode (at least this is how it seemed to work in the alpha version of the code). I just performed my first beta upload and performed the radio and mode switch calibrations per the latest instructions. Manual mode works fine, but when I switch to stabilize mode the throttle powers up to about half and I have no throttle control with the RC transmitter stick. Any suggestions?
    Yes, use the Mega Planner for waypoints.
  • Hi all, I have tested the ArduPilot Mega v1.0.3 alpha codes with Xplane and it is able to fly by waypoint. I’m also able to tune to Manual, Fly by wire B and AUTO mode.
    My drone,
    EPO cloud fly
    U-Blox GPS (workable)
    XBee module
    APM with IMU
    So, how to do program it to be able to fly the real thing? Do I still need to use the Ardupilot Mega Planner to load the waypoint in? Or there is any other method?
    Irvin, the APM Beta code works fine with Arduino 0021. Maybe you had a bad Arduino installation?
    I've now bolded that sentence in the manual so other people don't miss it ;-)
  • Chris Anderson please accept my personal apology. You are correct and I am wrong.
    To the community the mistake I made was not extracting the '.zip files to the "DESKTOP". Completely reading past the word without giving it a second thought.
    I have a series of 23 print screen Bitmap images that add up to a 16MB .zip file.
    Chris where is a good place to put it?
    Joseph Schauber
    Joseph: my only suggestion is that you do it EXACTLY like the example in the manual (okay, you can change "Chris" to "Joseph" ;-))
  • Chris I would like to add that I have been following along with you all day by day and have compiled and uploaded untold number of times in fact I have been working on my initial flight setup all day long. The "TEAM" has done a wonderful job.
    Thanks . Hats Off to You All !!!
    Joe
  • sorry Chris. I was trying to go thru my installation step by step but it was taking too long. At 70 i don't type as well as I used to. Cant see too well. I will work up a PDF and get back tomorrow . I hope.
    As written ArduPilotMega will not compile if the "libraries" are not in the arduino-0019 's "libraries" file folder that is created when one extracts the "arduino-0019.zip" file.
    my question to you is this; Could you possibly while developing/codding/debugging/etc. have these library files in the arduino's "libraries" folder? If you do that is the problem! If on the other hand you only have the standard "arduino packaged libraries" eleven in all in arduino's "libraries" folder , then you are wrong!
    Check that folder and delet all but the eleven libraries you will see what we are seelig. It does not matter what preferences :
    looks like.
    I have been around this tree a thousand times in the last three weeks.
    Joe
    Joeseph, I'm not sure what you're asking. What's the problem?
