Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
can apm handel deep stall landing?
Hi All!
I am Andrew Depalma, I am 24 years old and I am an Italian student in Aerospace Engineering at Politecnico di Torino in Italy. I have a big problem with APM.
I purchased APM pre-assembled and tested on Udrones in April. On X-plane simulation everything was perfect. I also tried to upload the firmware for the real flight (for airplane) just to test imu and gyro and everything worked.
But.. now I have a problem.
Two weeks ago, on 23rd July, for the first time, I tried to put APM on a RC aircraft, but the Autopilot, once I connected the battery, went crazy and sent “orrible” output to the aileron, rudder and elevator. The aircraft was on the ground and every mobile surfaces moved in a random way (not in normal way)! One aileron servo was broken!
And then, after this damage, when I connected again the USB cable to the APM (always mounted on the airplane), immediately the blue led on IMU was “on” and suddenly everything was switched off. For one entire day, this thing happened.
From 25th July until now, APM works, i.e. I can fly in X-plane, I can upload new waypoints, etc… but Gyro and accelerometers don’t work!!! I cannot find the reason!
On Terminal -> Test -> gyro moving APM nothing works! Same thing for Terminal -> Test -> imu
The numbers are 0 constant! (only Airpressure sensor works!) Obviously the Autopilot does not work on the aircraft!
Can you help me? I think that could be an energy supply problem. I am worried because now I purchased another IMU shield, but I am afraid that the same things can happen, because I don’t know the reason of the problem. Can you explain me what is the exact amount of power that I need to put on APM?
Have you any Idea about this problem?
(With a tester, I measured on the 3.3 V regulator and the tension is 3.3 V perfect)
I look forward your reply
Have a nice day!
Andrew
http://code.google.com/p/ardupilot-mega/wiki/RC
http://code.google.com/p/arducopter/wiki/ArduCopter_TradHeli
