ArduPilot: New Thermopile Boards!
Those of you following along with the ArduPilot development probably suspected that we weren't going to stick with leaving the stabilization function to the off-the-shelf FMA Co-Pilot for long. And sure enough, integrating those thermopile sensors into our autopilot has always been part of the plan--it's cheaper, better and more flexible. But how can we handle both stabilization and navigation with the modest Arduino chip? Well, you're just going to have to wait and see--trust me, it's cool ;-) In the meantime, here's the hardware Jordi designed to build your own two-axis thermopile sensor, in surface mount (SMD) form, which is small and light (shown above), or through-hole, which is easier to solder, shown below. It's related to the Paparazzi sensors, but optimized for Arduino. They will not work with the current ArduPilot, which is designed to work with the FMA Co-Pilot, but instead are designed for a future ArduPilot board. So why are we showing them to you now? Just because they're cool, and if you build them now we'll give you a reason to use them soon enough. Warning: the individual thermopile sensors (this board needs 4) aren't cheap at low volume: almost $18 each. At the volume we're buying (100s) they fall in price to just $6 each, so unless you're keen to get going quickly on this you might as well save some money and wait for us to build the boards and sell them assembled. But for those fully infected with the DIY spirit, the component list is below. Code and other integration instructions coming later. Through-hole version:
Components:
C1,C2,C3,C4,C6 5 x .027uF P4518-ND
C5 0.01uF 1 x 495-1065-1-ND
IC1 1 x AD8552RU AD8552ARUZ-ND
MOLEX PRT-08231 SparkFun
R1,R4 2 x 200 200EBK-ND
R2,R5 2 x 0.8M 820KEBK-ND
R3,R6 2 x 510 510EBK-ND
R7,R8 2 x 604 620EBK-ND
(TP1,2,3,4) 4 x MLX90247-ESF-DSA
SMD version (shown at top):
Components:
C1,C2,C3,C4,C6 5 x .027uF PCC1833CT-ND
C5 0.01uF 1 x 478-1383-1-ND
R1,R4 2 x 200 P200ACT-ND
R2,R5 2 x 0.8M P806KCCT-ND
R3,R6 2 x 510 P510ZCT-ND
R7,R8 2 x 604 RHM604CCT-ND
    Ted: No, they're protected by a FMA patent. So we recommend you buy the FMA ones instead.
  • When will you guys be selling these?
    Ted
  • Nice work dude,
    Anyway, can we use this thermopile board with parallax propeller microcontroller?
  • Because of the high cost of the thermopile's, has anyone looked in to where we could get them from. By the looks of them, they might be used in automobile's for the heating and cooling.
    Just thought maybe a cheaper way of getting them would be extracting them from temp control units in vehicles.
  • thank you Chris,
    you are right about the smd boards, they are very troubling to solder for amateurs like us.
    i have already ordered boardino kit from adafruit and gathered other components. however i am having trouble finding the attiny chip you have listed, in my country. maybe i can find an equivalent... :(
    We have not released any ArduPilot code yet (we're still testing it on the hardware). We're also not shipping boards yet. I would recommend that you order the boards and parts from the links in this post (go for the through-hole version; the SMD version is too hard for most people to solder). By the time you get those parts, we will have released the code.
  • by the way, i will also have trouble with arduino code, can you give me the latest code of the ardu-pilot? i have downloaded one previously...
  • Chris,
    great news... i will try it with your ardupilot but i donot have your board. i hope i can make it here in my country with the provided eagle files.. by the time being can i test the system with a standard arduino? if i can i will make some tests with my plane with 2 of the controls given to co-pilot ( this co-pilot has also a ch5 connection for remote on-off switching) and post my experience. you can also make use of it because this co-pilot is cheaper
    bGatti,
    I don't know, but I can imagine that it could be an issue.
    Dincer,
    That does look very similar. I wouldn't be surprised if you could make it work with ArduPilot Pro. Needless to say, it will work fine with the basic ArduPilot, because that autopilot can use any stabilization system that controls the ailerons and elevator by itself. The basic ArduPilot just controls the rudder (for navitation) and throttle (for altitude control)--it doesn't have any connection to the third-party stabilization system at all.
