3689462974?profile=originalSo I have some vacations coming up and already have some quads and a hex I figured I needed a fixed wing to round out my aerial camera fleet. (for now) heh. So I took the plunge and picked myself up an X8 to fill up with electronics.
3689463094?profile=original
I'm running an ArduPilot Purple, with a Castle 75 esc waiting for Hobbyking to drop of my new Scorpion motor until then I have a 700W max 50Amp local hobby store motor to power the bird. I'm running 1.2 video feeding through MinimOSD with a Sony 720 line mini cam. I have a roll and tilt GoPro mount in the works that I'll post up some pics when I can get some play time on the  router this weekend. Communication is done through a Futaba 10C 72Mhz and some 900Mhz XBees.
3689463151?profile=original
I've only made a few mods for now like adding a second motor mount plate that bolt through the foam to the outer plate.
3689462999?profile=original
I made some electronics trays and filled in the lower camera cut out with some foam and Gorilla glue.
3689463160?profile=original
3689463274?profile=original
I ended up bringing the control linkage up through the wing, leaving it on the bottom seemed like a bad idea for a belly lander. I have never flown a or built a fixed wing, but I said the same about the multirotors and DIYDrone's gear and community made it simple, awesome and enjoyable. Only crashes were ah-hem user error. So I'm hoping for the same luck with this bird. I do have tons of hours now on RealFlight sim just to make sure I feel comfortable with the controls. That being said any input from from you guys will be greatly appreciated. I'll update this blog as things progress and as I get the camera mount going. But for now heres some more eye candy. Be happy and safe all!
3689463229?profile=original3689463317?profile=original3689463299?profile=original3689463186?profile=original 3689463358?profile=original
  • Yes please post the parameters.
    Got my X8 and want to fly asap but not without good settings.
    Come on guys !!
    Can you share your pid settings? Are they working fine?
    Anyway, after 4 months with this topic can someone post some good parameters? :)
  • I'm still looking at all the folding options out there, but it has survived 6 flights now !
  • looks good no folding prop?
  • Went mad with a spray can....
  • 3692533902?profile=original3692533693?profile=original
  • Drop me your email and i will forward you the file im using.
  • So Im only hrs off its maiden. Where exactly can I find the PID Parameters to download? or do I type them manually in from the posted picture near the start of the thread?
  • sorry to hear that also but let us know if you find out what happend
  • Sorry to hear Rick,
    This is the sort of situation where a joystick via telemetry MAY be useful...I am including one in my setup and I intend to do a write-up on how that goes.
