Disclaimer:- DIYDRONES does not advocate or condone any RC flights beyond LOS or above 400'AGL. Do not try this. This APM assisted FPV was supposedly attempted in Russia. Such Flights may be illegal in many parts of the world. Members/ Diy UAV enthusiasts are advised to check with local regulations/authorities for required permits & comply. DiyDrones bears no responsibility for such action.
Prototype of the compact UAV on the basis of popular model of the radio-controlled EasyStar plane
Basic characteristics of a glider:
initial look:
Material ELAPOR
Wingspan: 137 cm / 2400 quarter sm.
Loading: 3,28 kg/sq.m
Fuselage length: 86,3 cm
Weight: 680 g
Changes are made to a plane design:
Ailerons are cut through
The rudder is increased by 100%
the tail beam (3 carbonic rods 1мм at sides and a bottom) is reinforced
wings are straightened t and in this position are reinforced by three bars everyone
the niche in a tail beam under the 7-inch screw is cut out
servo are mounted near surfaces
motor 250w 2200KV
esc turnigy plush 30A
APC 7*5
This configuration gives near 1kg pool (static measurement) that allows to provide reliable take-off.
Autopilot:
APM 2.5 flight controller
GPS external mediatek 3329 speed of updating of data 10Hz
Voltage sensor
The separate UBEC power supply for avionics
FPV equipment:
720 lines camera with high sensitivity
Video the transmitter 5,8GHz 200mw
video receiver 5,8GHz
FatShark video glasses
Battery:
Zippy Flymax 3S 5000ma (external on the bottom of a fuselage)
Russian style hummer-drones laboratory
elevator servo and rudder size
rc receiver and self-made apm2
No I do not think it is a fake, I just like playing around with the KML file.
Unfortunately radio modem is not used, dataflesh log is not saved after fly
if you wаnt i can upload mission and settings files
I hope you do not think it's a fake?
Please upload your log files.
Gosh I wish I had a shed/greenhouse/carport like that...
Very well put, Andrew.
Göran, how about allemansrätten for the skies? If people are given a reasonable safe space to do as they wish, none of this is a problem.
Göran, what's the difference between a foam UAV that weights a kilo or two and a Canada goose that weighs a couple more? The risk from wildlife is an accepted risk for manned flight, even when cruising in the flight levels, and it's a million times or more a risk to aircraft than a lonely UAV or two.
Bear in mind that this is SIX orders of magnitude at least difference in risk. If you could reduce the risk of something by six orders of magnitude, you'd be a hero!
ok, that's more like it. Hatt's off to the X5 pilot at 8400m
Also, as far as I understand, the highest ceiling anywhere in Australia for class G is FL180, so this effectively puts a limit on Australian-based altitude record attempts without talking to CASA. (and good luck with that...!)
1
2
of 2 Next
