I built a V shaped with 12 motor and coaxial prop
I know that the V shape is patented by Asctec.
This is a test only for learning purpose.
Is based on Coridium ARMmite pro controller.
Motor: keda 50-20s with 8x4.5 prop
Gyro ITG3200, Acc BMA180, Lipo 5000 mAh
Hi Juan,
They are two separate sensors, but have the i2c bus in common
I know what @wilfred means... a patent does not seem to fit with the open-source flavour of this community.
Actually, a patent does not prevent you or I from using this design, only from making money on it.
-and nowadays, it does not even seem to prevent that. [can you spell C. H. I. N. A?]
It's an IMU or individual sensors?
@ Roberto, you are generous in your comments, thanks
It would be nice if I could use your hardware (MP32) , right now I think it is the best for this type of application.
For patented V shape: http://mikrocontroller.com/files/AsctecPatent.pdf
Yes is patend by Astec if you search online you can found it. Danilo are doing a great work with his code and configuration . He start his project before my first code on ARM MP32 start to work. He is a veteran of ARM :)
best
Roberto
very stable.
some news about armquad ?
