ArmQuad V12
 I built a  V shaped with 12 motor and coaxial prop
I know that the V shape is patented by Asctec.
This is a test only for learning purpose.
Is based on Coridium ARMmite pro controller.
Motor: keda 50-20s with 8x4.5 prop
Gyro ITG3200, Acc BMA180, Lipo 5000 mAh
  • Hi Juan,
    They are two separate sensors, but have the i2c bus in common
    I know what @wilfred means... a patent does not seem to fit with the open-source flavour of this community.
    Actually, a patent does not prevent you or I from using this design, only from making money on it.
    -and nowadays, it does not even seem to prevent that.   [can you spell C. H. I. N. A?]
  • A Patent has to contain Unique and original demands, otherwise, it's only Bluf !!
    I does not read German, and I would like to have an English or French version of these demands ?
    Anyway, it is not in mind of Doh It Yourself :)
  • It's an IMU or individual sensors?
  • @ Roberto, you are generous in your comments, thanks
    It would be nice if I could use your hardware (MP32) ,
    right now I think it is the best for this type of application.
    For patented V shape: http://mikrocontroller.com/files/AsctecPatent.pdf
    Yes is patend by Astec if you search online you can found it. Danilo are doing a great work with his code and configuration . He start his project before my first code on ARM MP32 start to work. He is a veteran of ARM :)
    best
    Roberto
  • " V shape is patented by Asctec"
    Really!!?!!
    Great Work Danilo :-)
  • very  stable.
    some news about armquad ?
