Hi guys,
Have some pictures of the AUAV-X1 board with connectors - top side and bottom side. Also some scopes applied - input voltage from 4V to 8VDC and different loads - 0.5A and 1A.
Some picture explanations - from top to bottom:
TPS63061_4V_1A
TPS63061_5V_0.5A
TPS63061_7V_1A
TPS63061_8V_0.5A
The temperatures are respectively - 34.5 deg C of the TPS63061, 31 deg C of the Schottky diode, 28 deg C of the inductor. They remain stable within an hour measurements. The output voltage is perfect stable - 5.05VDC. The LDO output voltages are between 3.305 and 3.312VDC respectively.
Best regards
Nick
Hi. On the front view. Avoid using red(+5V) on pink background ( use other background colour). On back view check (+3V SF). PCB view is good...
thanks nick!
Felix, I wish they were ready to go. That is still a pre-order. The boards are flying here now, but the IMUs still need to be sent to a US surface mount vendor in order to be finished. So close, we appreciate everyone's patience.
Looking great guys! I see it's now "in stock" in the usa storefront... nice!
Hi Mark,
The SIPI color is fixed.
Best regards
Nick
Nick, those pictures are very nice. Two comments on the front view:
1) the color used for SIPI doesn't show up well on my screen
2) are "additional channels" PWM inputs?
thanks, Mark
Hi guys,
What do you think of the attached pictures....are they clear enough to be used in the manual?
Yes, for sure....working on at the moment.....
are you going to create a little manual for you board?
Hi Nick ! It is really great to hear that AUAVX-X1 is being planned for the competition flight. When you are planning to do few informal test flights and post the results so that many people who are interested to buy it can have confidence of Hardware perfection and firmware compatibility.
1
2
3
4
of 4 Next
