Autonomous Flight at 39 Grams, No Registration Required
3689674564?profile=original
If you're looking for an autonomous aircraft without the need for registration in the U.S., Paparazzi UAV and 1bitsquared have got you covered. The Lisa/S quad has a takeoff weight of 39g(0.086 lbs.) That's way below the FAA registration limit and still leaves plenty of head-room for payload, approximately 210 grams worth.
Here's a link to the kit: Lisa/S Nano Quadcopter Kit
  • What is the lifting capacity of this?
  • ... and there is now a companion computer available for 5$ to experiment with in this nano size category; The Rapberry Pi Zero
    http://diydrones.com/profiles/blogs/raspberry-pi-zero-launched-towa...
  • Nano copters unite!
    For those interested in the Lisa/S Nano Copter, TUDelft MAVLab put together a nice tutorial that includes a short autonomous flight clip. Enjoy.
  • Not to hijack this topic, but this was in june 2014:
    https://youtu.be/a6yVU6KhlNU
    AutoQuad M4, full autonomous, 42gram, HoTT telemetry, Android GCS/QGroundcontrol etc
    Around 7 min @ 1S 320mAh
  • There are a couple of interesting options in the sub 250g. range.
    What about the Hermit Micro FPV  racer  (getfpv.com) integrated with the new XRACER v1 Autopilot (http://www.auav.co/product-p/xr-v1.htm)   " The XRacer V1, the latest next generation PixHawk derivative flight controller.".
    3702144303?profile=original
  • Wow, that is incredible. What sort of flight times does it manage? Can it handle any wind? I'm assuming it's for outdoor use given the GPS.
  • MR60
    Light drones, under the regulation weight, with same sensors capabilities as the >4kg drones, are the future and the way to go. I expect only large corporations will ultimately have the means and resources to comply with regulations for bigger drones carrying heavy payload (they create and lobby such regulations)
    Top notch
  • Wow, its really great achievement !
  • Of note, this autopilot was developed in cooperation with TU Delft MAVLab.
    Micro Air Vehicle Laboratory
