Autopilot brownies
The reflow oven went haywire at DIY Drones HQ, and these melted ArduPilot Megas are the result. That's one batch of beta testers who are just going to have to wait a bit longer for their gear :-(
  • More than a year late, but...FYI...If you are using the max6675 as the temp sensor with K thermocouple...then bit 2 in the serial bitstream tells you if the thermocouple is valid/connected or not. A good bit to test and shutdown if it's HIGH.
    Also: Do you know your PID coefficients by chance? I've made my own oven and tuning it now.
  • Can I get mine w/cheese plz?
  • You learned the hard way about single point failure. I know a lot about high temp lab furnaces.
    Iv'e been fixin/buildin em for ~ 18 years. You need to have an independent overtemp/alarm back to the dual temp sensors. Temperature is like Velocity it can be .... you know the rest ..
  • I think Jordi way overclocked the CPU
    Jordi, you could add a few temp probes and set hi/low alarms, each probe to be monitored during bake cycle, place them in different places and record normal cycle temps then set up alarms based on test log. They could also keep your exhaust fans going. Those got to stink...
  • Hey Chris, I am just in........
    You can,t take all the brownies man !
    I don't know. I just drop them away. Also their unusable because the black thing is very difficult to remove.
    Ok, i found out the problem, the TEMP sensor i dead. Second version will have two temp sensors for redundancy. ;-)
  • Hay Chris, you smell something burning ?????????
    Earl
  • i like to dabble in organic computing too
