AutoQuad ver 5
3689387530?profile=originalI know, the world probably has enough flying machine projects, but here is yet another one.  AutoQuad's original design goal was high precision autonomous flight.  It took five prototypes before I was happy with the hardware.  The current prototype, AQv5, is showing very promising results.  In fact, there is little left to do before this first goal can be checked off  the list.  Using this as a solid base, I intend to continue research, design and experimentation toward vision based navigation for indoor and outdoor use.
Hardware:
- 2" x 2" board with same mounting pattern as the MK FC
- Input voltage ~7.5v => 18v
- High efficiency DC/DC converters
- STM32F103 32bit Cortex M3 microcontroller @72 MHZ
- standard ARM 20 pin JTAG header for real-time debugging
- up to 8 PWM ESC motor control (prefer Turnigy ESC's with custom firmware)
- 2 powered payload servo controllers
- optional ultra sonic range finder
- Spektrum satellite (remote receiver) 2.4Ghz RC radio
3689387605?profile=original
- uSD card slot
- optional onboard uBlox LEA-XX module w/battery backup & timepulse capture
- optional female SMA connector for active GPS antenna
- optional external GPS via standard 6 pin connector (EM406, EM401, uBlox, MTK)
- optional onboard xBee module - up to 300mA (2.4Ghz, 900Mhz, bluetooth, etc.)
- optional external radio via standard 6 pin FTDI connector - up to 1A
- I2C bus connector for I2C ESC's
3689387476?profile=original3689387631?profile=original
- modular sensor board (SBv5) - 100% analog sensors, EMI hardening:
+ 3 axis acc (ADXL335)
+ 3 axis mag (HMC6042 & HMC1041Z)
+ 3 axis gyro (IDG500 & ISZ500)
+ 2 temperature sensors
+ pressure sensor (MPXH6101A)
+ battery voltage
3689387558?profile=original3689387492?profile=original
Software:
- Fully threaded RTOS design written in C -  60% idle
- All sensors read at 113KHz (~1.4M sps total)
- 450Hz motor update rate
- 200Hz attitude, 3D velocity / position solutions
- Full downlink telemetry
- Detailed system state dumps @200Hz => uSD card w/FAT32 FS
- Quaternion based attitude filter additionally producing rotation matrix and Euler angle outputs
- All math in single precision floating point
- Temperature compensated and calibrated sensor suite
- Custom ground station software w/bi-directional command and control API
- Cascading PID control system, velocity based for smooth transitions
- Auto land / takeoff
- Hover position / altitude hold
- Autonomous waypoint mission navigation
- Precise altitude hold indoors
Example of current capabilities:
Design philosophy:
- High performance
- Efficiency
- Ease of development
- Consistency / Repeatability
- Low cost
There is always room for improvement.  For instance, I would like to see how much of a benefit using a SPKF (Sigma Point Kalman Filter) would be over my fixed gain navigation filter.  Looking forward to the new Cortex M4 uC's with a hardware FPU so that any such math intensive solution can be more easily handled.  As I mentioned above, there is a lot of room for work with vision navigation and SLAM.  Also interested in propulsion efficiencies which with an eye toward higher endurance.  Although the PID based control system works extremely well, I'm interested in exploring different types of MPC (model predictive control) to reduce control costs and increase precision.
I'm wondering if there is anyone interested in joining forces to work on some of the above mentioned or anything else along these lines that presents itself.  This is only a hobby for me and I currently have no profit motive.  This is definitely not a beginner's project as you can see by my sloppy SMD hand soldering job.
Comments?
  • Flemming: Don't know.  Possibly.  Anyone who is interested enough to need a board to attempt a build should probably contact me.
  • Thanks for posting the design, will be learning a lot from it! Using a "port" in the schematic is new for me, looks useful (and available in Eagle Cad). Of course some questions:
    - What is +Vdda used for, or is it just a spare source?
    - Is it true that (for example) the internal GPS VDO is still (when in full use) dissipating (6.5-3.3)*0.150=0.48W? Or is the resistor R23 somehow limiting this, also, why are you not using the same construction for Xbee regulator?
    Sorry for such basic questions compared to the discussion about all the mathematics.
  • Thanks for the schematics. I do have a question you now sample at 113kHz and down scale it to 200Hz that is like 6bits extra ? wouldn't it be much better to get a higher resolution ADC like 22bits  also with a high sample rate.
  • Cool with some hints about how it's done, jpegs aren't going to be very easy to build on, so will the actual source files that can be edited with a cad package be released?
  • For anyone who's interested, schematics and BOM are available at:
    http://code.google.com/p/autoquad/
  • this is a real super stable code.
    the arducopter and some other based on the same code fly too poor ! toons of wooble.
    i want one.
  • Roy: Not exactly.  The simulation is a replica of the onboard code.  Given sensor raw voltage readings recorded from an actual flight it computes the exact same estimates of states.  Now if you change a runtime parameter (like the amount of GPS error to apply to the position state) the simulation will show what impact that has on the calculated solutions over the whole flight and can be scored.  That simulation is wrapped in a parameter estimation filter (SRUKF) which simultaneously tries to find values for a few dozen such parameters which tend to make the solution "better."  Turns out that half the battle is defining what "better" is as you don't actually know what the true states where at the time, but that's another conversation.
  • Brian: "I know exactly what you mean.", Morpheus :)  I think the problem is that the velocity errors show up for more reasons than true acc bias.  Other than GPS measurement noise, the largest is probably attitude estimation error.
    Until one can estimate the attitude error (which if you could do that, you could simply correct the error) you have to lump all *apparent* biases into a single bucket.  I chose to store them in the body frame as they most certainly are at least partially composed of true acc bias.  But definitely do not try to use them as correction terms to acc inputs to your attitude filter - as you experienced.
    The better solution is to have a filter which can separate the apparent bias into its true components and apply them appropriately - some of it will be body=>world rotation errors.  I have had success in doing this offline in simulation with a SRCDKF (Square Root Central Difference Kalman Filter) as this is a non-linear problem.  Of course the problem is that we cannot yet run a filter of this complexity onboard.  Research is ongoing, but meanwhile we have a solution which works reasonably well.
  • Nima: Yes, velocity of the craft in the world frame is the integration of the rotated body frame accelerometer data and position is the integration of the velocity. When velocity updates come in from the GPS, estimated velocity states are adjusted by a factor determined by the current accuracy reported by the GPS. Some of the error is also attributed to accelerometer bias. When position updates come in, position states are adjusted in a similar fashion. AQ does not use KF filters onboard.
  • So it not for aliasing but more for better precision. Not possible with my current setup. I thought 16bits would be high enough.
    I hope for some more detailed info on your IMU very interesting, and nice learning material.
