BAT-SAFE for lipo charging
3689682798?profile=originalBAT-SAFE is a low cost safety device developed by Tom Mast, aircraft design engineer. It's easy to use, and literally put a lid on the dangers of malfunctioning batteries. They just released a Kickstarter campaign. It has the potential to become a standard to people that use lipo batteries and want some piece of mind.
  • It's a bit of over-kill, IMHO
    Flite Test has a couple of "battery bunker" ideas on their website that are safe, effective, and inexpensive.
    A simple cinder block and a bag of sand for a fire suppressant are really all one needs for charging.  I transport in a $7 metal ammo can.
    http://assets.flitetest.com/article_images/full/flite-test-battery-...
    http://flitetest.com/articles/lipo-battery-bunker
  • T3
    @Mike you should not reply to Darius, he is a notorious troll.  Check his previous posts.
    Your product looks great!  I am going to get one, the peace of mind is worth it.
  • This looks like a great product at a very competitive price, but...
    Dude.  That voice-over is going to kill your campaign.  Everything else seemed well polished, but that alone made me have second thoughts about your viability and prompted me to hold off on backing.
    Hire an actual voice actor online for some nominal amount and get that god-awful text-to-speech out of your Kickstarter video.
  • @Darius - I hope you charge your lipo batteries near your computer, it gives the rest of us hope that you will burn your computer down and the rest of us don't have to listen to your incessant moronic trolling.  Go away.
  • I charge LiPOs on top of my gas cooker in the kitchen. As it is designed to have the open flame there in the first place .. :)
  • Another horror story and horror product
    The Design (Patent Pending)
    So after analyzing the problem I designed an insulated double wall steel box that contains the fire and intense heat, the smoke and soot is filtered through a steel and fiberglass flame arrestor which also reduces the heat of the exhaust gases. The clean and relative cool smoke is vented out of the box to prevent the box from exploding.  The battery still produces a large quantity of smoke but it is clean and free of soot and will clear out quickly.
    It's not smart to offer product intended to burn Li-Po batteries to generate heat, exhaust gases, flames, to be operated at home (indoor).
    All efforts should be directed to build safe charger and safe Li-Po batteries.
    Safe charger is one equipped with temperature sensor to prevent overcharging.
    Drone Li-Po batteries should come with temperature sensors by default
    to prevent overcharging, fire due to excessive current consumption.
    But it doesn't make sense to build a box to burn Li-Po batteries at home.
    Replace metal box by plastic box with both inlects, outlets
    and temperature sensors.
    Never charge your Li-Po batteries closed in the box since free air flow cooling exactly prevents any fire.
    Acting otherwise you built Li-Po batteries cooker
    Read Li-Po batteries  ISO, EU charging, handling standards first.
    no reply please
  • Excellent product! I use 50 cal ammo cans right now with holes drilled into them.
    Too bad shipping to Canada is listed as $40 and the box is only $29.
  • Good idea Xon, to have a little instalation inside with vent outside to charge batts if that is the smoke :O
  • Nice, I do have lipo-fire paranoia lately. I think the more that drone users progress with old lipo batteries from the day they purchased their drones back a few years, the more chance of fires. I've taken to keeping them in a big old ceramic pastry bowl, but a decent product is a good thing so well done.
  • Brilliant product, brilliant price.  This should be mandatory for every battery user!
