Battery?
I have a narrowed down parts list, but am at a loss for a battery. I don't have much experience w/RC planes.
What should i get to enable this setup to get the longest flight time possible. (2hrs?)Total without battery comes to $680. This list is in a more complete form here.This will be my first RC, but not my first robot.
  • I would guess that a small brushless with a 3s 2200mah lipo will get you 25-35 minutes in the air with cruise throttle. So that's a current draw between say 3.5 and 5 amp/h. That's before adding the extra weight of video gear. I also don't know if that glider can cope with a large 5amp battery for those longer flights.
    I will be testing that set-up in the next week or so but with a 4400mah 3s 11.1v lipo batt.
    Well gooooooooooo brushless first and then look at it seriously, you certainly need to separate flight power from downlink. Also note flights greater than 30 minutes will require Notams in the future. So you might want to make 29 minutes your flight time ;-)
  • I think the best way is to rip out a calculator and the spec sheets or a current probe and measure the consumption for each of these parts. Then add all the currents up and do the math to see what power budget you have. Then you will know what the current draw down is and you can select your battery after that.
    LiPo technology is the best power density we currently have that is workable.
    Rgrds
  • noooooooooooo -> what kind of lipo exactly. thats the point of my inquiry...
    I think you will struggle to get 2 hours out of an easy glider, especially in a brushed fit, right away you need to go brushless.
    So its lipos for you!!
    Also separate flight battery from video/downlink. So thats two lipos.
    Good luck
