My aim is to make a simple Ardupilot setup on a EasyStar for strictly £400 or $650 (but shipping is expensive globally as I'm in the UK). I have the Fidi programmer and reasonable Arduino experience so thats not a problem but I want to know, for instance whether the 4Hz GPS is worth the extra $100 etc. (I already have the 32 Channel LS20031 GPS 5Hz Receiver carried by sparkfun) and a Spectrum DX5e w/ receiver.Any mods to the EasyStar worth doing to start with? (I can get it for £80 inc. delivery)I know that its probably covered else where but not all in one place.Any comments would be much obliged.
So I mod up the EasyStar, and I need the Adupilot main board, the shield, the XYZ thermopiles and I can use my data radios. And I need some female cables to connect everything up. Have I forgotten anything?
Hi Giles, it will be be interested to see how you get on. I too am building a system for the same price as you and live in the UK. I have ordered everything except the XBee and GPS chip wasn't sure what to go for (uBlox or the EM406!) I have gone for the AXN cloud as to fly (its looks identical to the easystar but has ailerons - cost about £60 delivered from china - they have them on brc hobbies) - it should be here any day!
Haven't got the telemetry yet as am not completely sure on frequency restrictions in the uk as i want to stream the video aswell!
There is a UK store that sells most stuff you need - (www.coolcomponents.co.uk). I got the Ardupilot from there but it worked out cheaper to get most of it from the diydrones store - even with postage!
Given that you've already got the RC gear, your budget seems fine. All of the ArduPilot equipment, including wireless telemetry and a ground station, is less than $400. The EasyStar with the brushless upgrade is about another $100. Beyond that, your only big expenses would be any camera or video equipment you want to add.
The two messages you need to make sure are enabled on your GPS are GPRMC and GPGGA. Typically you can send a $PMTK314 command to enable and disable NMEA strings.
Giles, you can use your LS20031 (ArduPilot has a NMEA parser, so you can use an NMEA GPS), but we won't be able to support it since we haven't used one ourself. The only two officially supported GPSs are the uBlox and the EM406.
As for the EasyStar, I would really recommend a brushless/Lipo upgrade. It's pretty underpowered in the stock configuration.
PMTK commands can be found here:
http://www.sparkfun.com/datasheets/GPS/Modules/PMTK_Protocol
You'll probably want to use:
$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28
$PMTK313,1*2E
$PMTK301,2*2E
$PMTK220,200*2C
