Hi All
The Big Black X8 Wing is now in stock at FPVflying.com
Wing span : 2122mm
Wing area : 80dm2
Valid payload : 1000-2000g
Requires for flying :
Folderable prop 12 * 6 or 12 * 8;
2 * 20g servos(the size of servo hole on the plane is 40*40mm);
60A ESC or bigger;
4s 6000---10000mah lipo
More info: X8 Wing for UAV flying
It's rated to take up to 2kg payload...anyone with one think it might carry 3kg with a bigger esc & motor and keeping it gentle and fast in flight??
Hooks, or anyone else, do you have an APM parameter file for the X8 yet?
Don't know what happened to the link. It's now corrected.
Correct Link
HERE
@arashi, thanks for the update!
i like it a lot.. probably a low radar cross-section, if you could find iron ball paint, you might get a stealth drone of your own :)
Of cause wings are detachable. who got a car that can handle a 2.2M flying wing...
And four screws for the winglets
The wings are removable. The attachment uses two carbon fiber tubes and a plywood plate. Only two screws are used to fix the wings.
Ive been reading the RCG thread and it looks a like a few people have used plywood plates and a mounting screw to make the wings detachable.
