Coming soon: MinimOSD!
3689432293?profile=original
Hi guys! I'm giving you a preview of an upcoming product from the DIY Drones store, the MinimOSD, a minimal Arduino-based on-screen display board. It's tailored for use with ArduPilot Mega and the MAVlink protocol, and designed to be as compact as possible.
It's main components are an ATmega328P 8 bit microcontroller with an Arduino bootloader, and a MAX7456 monochrome on-screen display. Programming is done through an FTDI-compatible 6-pin header.
It features two independent power and ground sections to isolate the OSD's analog stage: a +5V section for the ATmega and the OSD's digital stage, powered through the FTDI cable or other +5V source; and a regulated +5V section for the OSD's analog stage, powered through the video in/out header and capable of handling up to +12V input. Solder jumpers are available to combine the two power and ground sections if desired.
Spec lists are the best, so here's one!
  • ATmega328P with Arduino bootloader
  • MAX7456 monochrome on-screen display
  • FTDI cable compatible pinout
  • Standard 6-pin ISP header
  • Two independent power sections with an LED indicator on each
  • Solder jumpers for combining the power sections
  • +5V 500mA regulator for up to +12V supply input
  • Solder jumper for PAL video option
  • Exposed test points for HSYNC and LOS
  • Dimensions: 0.7"W x 1.7"L (2.4" w/ pins as shown) x 0.3"H
The production version won't be green, and we're not too fond of blue anymore, so expect something different on future products ;)
(And yes, I know I missed a decoupling cap on the board in the photo. Sorry Chris!)
Expected release date is within 2-3 weeks, price is TBD. Watch this space! UPDATE: Price will be $89.99 USD.
  • DIY osd: Arduino pro mini: $15.80 + Breakout Board for MAX7456: $39.95 = $55.75
    The price is quite high, it's not so hard to do a DIY osd from the above components. This one it's even cheaper, it doesn't use the MAX7456 ic.
  • Yes, idelay it should have 2 analog inputs for RSSI (main controller receiver, and XBee, at least).
    Updated price! 89.99USD
    Wow, MAX7456 is not the cheapest ic, but I consider quite a high price tag.
    I just bought the Apache/HobbyKing OSD Pro, but I knew that would just be for the FPV EZ, since Chris has mentioned previously that an OSD tie-in to APM was coming down the pipes.
    Great news.
    (I also wonder about RSSI)
  • Hi:
    Does it include a input pin  for  rc receiver's RSSI  (analog voltage )
    tangtl
    apocolipse: With a Y cable. Please wait for the product to be released for further details.
  • I'm still confused as to how to hook up an Xbee AND this minimOSD
  • And I just bought a Remzibi. Doh!
    Mark: That's correct.
    Do I understand this properly?  It has two inputs -- video and MAVlink stream, and outputs a video signal with some of the MAVlink data overlaid?
    apocolipse: No, it shares the port with the Xbee. They get the same MAVLink stream, but the OSD just uses the data that's relevant to a video overlay. The Xbee is unaffected.
