After months of testing by the beta-testing team, Copter-3.3 is ready for wider use. Similar to the Copter-3.2 release this is a "soft launch" meaning that for the next couple of weeks, we are asking users to load the new version using the Mission Planner's "Beta firmwares" link on the Install page. The MP will pop-up a "use at your own risk" message but rest assured, this firmware has been very thoroughly tested.
We also recommend that you use the Beta Mission planner until Copter-3.3 becomes the default (in about 2 weeks). Open the Mission Planner and select Config/Tuning >> Planner and click the Beta Firmware checkbox. Then Help >> "Check for Beta Updates". The download and install will take a few minutes.
Unfortunately this version and all future versions of Copter only work with fast CPU boards like the 3DR Pixhawk (and compatible) boards, VRBrain, NAVIO+, etc. Slower CPU boards will continue to be able to load the Copter-3.2.1 release.
Issues should be reported in the APM Forum.
The wiki has been mostly updated but if you spot missing items please report them to the wiki issues list.
The full set of changes can be seen in the Release Notes but the highlights are below.
Known Issues/Warnings:
- users will need to re-calibrate their accelerometers because of 5c (accelerometer range increase).
- FrSky telemetry users must set SERIAL2_PROTOCOL to "3" and reboot the board to enable FrSky telemetry like in previous versions
- this version corrects a long standing issue in the HDOP reporting so values will appear about 40% lower than previously but this does not actually mean the GPS position is better than before.
Changes vs Copter-3.2.1
1) EKF replaces DCM/InertialNav for attitude and position estimation which provides more feedback and robustness in case of sensors failures
2) Control improvements:
a) battery voltage compensation should maintain control as voltage drops
b) current limiting can be used to reduce the maximum current requested to reduce strain on battery and ESCs
c) air pressure compensation should reduce need for re-tuning when flying at different altitudes
d) improved throttle curve should reduce wobbles during descents
3) AutoTune for yaw
4) Cameras & Gimbal improvements:
a) SToRM32 gimbal support
b) do-mount-control mission command allows controlling absolute camera mount angle during missions
5) Vibration resistance:
a) real-time reporting of vibration levels by clicking on Vibe field on HUD (also recorded to logs)
b) noise weighted average of accelerometers used to weight IMU towards the one exposed to less vibration
c) accelerometer range increased from 8G to 16G to allow use in higher vibration environments (i.e. reduced "clipping")
6) Other:
a) improved landing on slopes
b) retractable landing gear support
c) channels 9 ~ 12 can be used as auxiliary switches (like ch7, 8)
d) PX4flow (optical flow) support in Loiter
e) Brake flight mode (stops vehicle quickly but requires GPS)
f) allow GPS, Telemetry, SToRM32 gimbal to be connected to any telemetry/serial port
g) Lidar-Lite V2 support
h) bug fix to RCMAP - remapped channel's MIN, MAX were taken from incorrect parameters meaning all channel ranges had to be the same
7) Tricopter tail servo parameters (MOT_YAW_SV_MIN, MAX, TRIM, REV)
8) Safety items:
a) crash check triggers with 30deg lean angle error (for 2 sec) even if pilot's throttle is non-zero
b) modified pre-arm checks to ensure good quality GPS and compas data
c) lost copter alarm (hold both sticks down and right)
d) motor interlock & emergency motor stop features on auxiliary switches (ch7 ~ ch12)
e) RTL_CLIMB_MIN parameter allows forcing vehicle to always climb a few meters at beginning of RTL
f) LED flashes green quickly if disarmed with 3D lock and SBAS
Special thanks to Marco and all the beta testers who put their vehicles at risk so we could iron out the problems during the testing phase and ensure a more reliable firmware for the wider community. Here are some of their videos:
ChrisN #1, #2, Paul Atkin #1, #2, #3, Gervais #1, #2, #3, Gleb Falaleev #1, #2, Pomaroli, Michael, Robert Baumgartner, De Le, Robert Baumgartner, Robert Navoni, Maciej Karpinski
Since when did going to minimum throttle in flight stop the motors? Unless you foolishly have the throttle min parameter set to something stupidly low, going to minimum throttle in flight doesn't stop the motors. And even if it did, it's not the kind of thing one can reasonably foresee people doing inadvertently. So the notion that cutting off the motors with a switch in flight is no different than going to minimum throttle is incorrect.
Neither the wiki or the video explain any of these other details on the interlock function you guys described in here. So don't get all indigent about me not knowing the details when they are not explained anywhere. Like I said, you guys come up with amazing stuff. The work you all put in to this thing is out of this world. Literally every feature and function is perfect. So it just baffles me that a new feature with such serious implications is rolled out with so little documentation and a haphazard attitude. It's not like you guys.
Thank's for the tip Marco; If I can convince my friends to use Ardu I'm going to give a try :) , they were impressed with the video. ;)
leonardthall: very usefull explanation in cases to use the Kill switch, perhaps is a good idea to add to wiki?.
Thanks again Leonard. I will have to set up a test rig to explore the 3.3FW and the spring loaded throttle options.
Is there any work around or options, for this high vibration scenario, without having the Stabilize mode available?
Hi Ronny,
I don't think the lidar will help your landing detection. The biggest thing that can delay the landing detection is bouncing or vibration on the ground. This makes it hard for the copter to tell the difference between the near ground turbulence and the vibration from the ground. So landing on a mat/grass or ensuring you have some rubber around your landing gear.
Altitude hold is also quiet a good fallback from GPS modes. The only danger is extreme vibration caused by a broken prop can mess up the alt hold.
Thanks for fast answering Leonard, and that is good to hear.
I fell that with the spring loaded throttle, holding constant altitude becomes easier and more consistent, at least for our use. In addition you should not have any catastrophic changes in height while changing flight modes (as long as mid throttle in Stabilize mode is the same as hover throttle in the "automatic" modes).
As of now we are using Stabilize mode as one of our flight modes, but I am not to found of this as some of our operators have accidentally triggered this in flight (with rapid altitude change as a result). It is nice to have despite this, if the motors need to be stopped like if the landing detector is missing out.
I guess the problem with the motors not stopping quickly enough due to landing detection can be improved with the use of the LidarLight2 sensor (I have one on the way for testing)?
One advantage of having the Stabilze mode is of course that if you get into "trouble" in the auto modes (poor GPS reception etc), you still have a chance of regaining control over the craft.
If completely skipping the Stabilize mode, how is the Altitude Hold mode in this respect as a "bail out" mode (with the new "Motor Interlock switch" as a extra safety to stop the motors on the ground)?
Btw. I liked Rob's protected "Motor Interlock switch" on the Taranis radio).
Thanks again for all your good work :)
RE: Motor interlock and emergency stop
This is a fantastic SAFETY feature! (Sorry, couldn't resist) I personally use the Motor Interlock option on my sprung two position switch on the top right side of the taranis. I have used this a number of times in flight and every time I touch down. I have a number of friends that fly arducopter with me and the additional confidence this switch provides the pilot is immediately noticeable to people using the default setup.
Advantages:
Disadvantages:
As I use arducopter for FPV racing (http://diydrones.com/profiles/blogs/fpv-racing-using-arducopter) I reguly clip a branch or blow a propeller up. Instant motor stop prevents esc's from catching fire and burning out motors. The position of the battery on my quad also means the copter tends to roll onto it's side during landing. Again, using the kill switch significantly reduces the chances of breaking a propeller or burning out esc's. The most extreme case this saved me was when I was doing some extreme vibration testing of the EKF and introduced a 45 degree angle offset resulting in a copter coming towards me at 100km/h in stabilize when it should have been level. The kill switch meant this ended with a couple of broken props and the copter came down quickly and safely. (High vibration handling of the EKF has been significantly improved now).
For the pilots that don't believe this feature provides a significant improvement in safety and reliability, for whatever reason, the good news is that it isn't on by default and you don't need to use it. Win Win Win. Having said that, any suggestions that we may use to make this better are always welcome!!!
Interlock feature is a necessity at this point for APM copter.I like it to have. Some laws (for example here in italy) asks for a feature to instantly kill the drone to be compliant with the law.
Thanks to all the developer and testers for the hard work!
Hi Ronny,
The sprung throttle stick is fully supported but probably not documented. All of the 3dr SOLO's are running with sprung throttle sticks. The only thing you need to be mindful of is while landing the copter wants to see that you are actually attempting to land. So if you descend until your copter just touches the ground then let go of the throttle stick, the copter will think you are attempting to hover just above the ground and not detect a land.
I think the motor interlock feature is fantastic. It adds an additional safety layer to prevent accidental arming, and it can save fingers or props when things go wrong...
I had some cases when my pixhawk franken phantom fell over after landing due to the flawed "landing gear". The normal disarm procedure (throttle down/yaw left) takes way too long in such a case. The interlock is perfect. one switch and all motors stop instantly.
2
3
4
5
6
of 8 Next
