Hi all,
I've made two videos showing the ArduCopter Auto (and RTL in second video) capabilities of ArduCopter.
The first video is a flight with 5 waypoints at varying altitudes and includes AutoLand.
I only did not include Auto Takeoff in these videos but can confirm that also works well. There was limited takeoff space so I took off in Stabilize mode and then switched over to Auto.
Still have to work on the jello effect, as it turns out I have one motor which causes a lot of vibration.
I hope this shows nicely how well this functionality works!
While flying I have had a continuous videofeed (as a failsafe) via FatShark Goggles and using MinimOSD for HUD projection overlaid on the video. Nb. the new 5.8 Ghz 600mW Tx from ImmersionRC works a treat even at longer distances!
The second video shows a flyover (at high altitude) of a local fair and a return flight via RTL.
@ Fernando: Thanks for the compliment! I checked your video and you have a pretty cool (and powerful) quad!
I used iMovie on my Mac to make the video. Has just enough tools for me and it came out of the box preinstalled on my MacBook. I actually have that laptop as a dual boot machine so both MacOSX and Windows 7 as I use that laptop in the field with Mission Planner under Windows
Thanks for the reply. Can you throw a mission plan or screen. I want to see how you put points autoland ...
Thanks for the video!!! Its really nice one!!! I have a custom frame too (a quad) and i use auto takeoff its relly nice feature. If you would like to see it working look the link.
http://youtu.be/v5_0GSzJoO4
By witch video editor did you use... it relly nice edition you´ve maded.
@ Vitalik: I use a cheap but pretty good camera mount from HK. The good thing is that it's 2-axis (pitch/roll) and if you have the right servo, you can pitch 180 degrees (up and down 90 degrees) while it can roll about 90 degrees (left/right 45 degrees). Link to Camera Mount
And yes, you can controll the quad (or hexa in this case) when in Autoland.
You can see I am moving the copter a bit away from the tree at the end of the video as I thought it was a bit too close. So I manually moved it a bit to the right while Autoland was in progress. During this adjustment I did not touch the throttle stick. This was the only control input I did during the entire flight and only because my home (and thus RTL location) was a bit too close to the trees.
Thanks for the great video. And what did you use suspension for the camera? When autoland can be controlled quadrocopter? Thank you!
