  • Hi Leo . very nice build  , how do you build the fuselarge ?  I thought of building a 4m wing version and can take payload of 5kg . Kindly advice thanks
    Ken
  • Leo and Vince, could you develop a composite airframe, for my needs?
    Please, PM with your contacts.
    Thanks!
  • Ravi, I would love to be in a position to offer kits now but we currently only have the prototype. I am working on the second one with some improvements. Having a fuselage mould will help a lot, which is my current task. Also looking at ways to make the wing saddle quicker. All I can say is watch this space.
    Thanks for your interest.
    Vince
  • can someone let me know what is the sourcing for holden drone airframe. i mean form where can it be bought.
  • Hoping to make a start on a new fuselage plug and moulds. Easier to draw than to make, unless my enquiries about 3d printing work out.3692571769?profile=original
  • Motocalc predictions
    Comparison - EAV
    100m above Sea Level, 101.3kPa, 18°C
                                   EAV
    Motor                          Pulso 4120/20
      Motor Constant (rpm/V)       465
      No Load Current (A)          1.1
      Armature Resistance (Ohms)   0.054
    Battery                        RC Lab 5500
      Series Cell Count            5
      Parallel Cell Count          1
      Cell Capacity (mAh)          5500
      Pack Capacity (mAh)          5500
      Cell Voltage (V)             3.7
      Pack Voltage (V)             18.5
      Cell Resistance (Ohms)       0.01
      Pack Resistance (Ohms)       0.05
    Speed Control (ESC)            Castle Creations Phoenix 60
      Resistance (Ohms)            0.0012
      Maximum Current (A)          85
      Number of ESCs               1
    Drive System                   APC  Propellers
      Gear Ratio                   1.00:1
      Propeller (in x in)          16x10
      Series Motors                1
      Parallel Motors              1
      Number of Propellers         1
      Blades per Propeller         2
    Airframe                       Holden Drone
      Wing Span (cm)               220
      Wing Area (dm²)              62
      Total Weight (g)             5048
    Static Predictions
      Current (A)                  39.0                       actual 44
      Motor Voltage (V)            16.5
      Input Power (W)              644.0
      Input Power Loading (W/kg)   127.5
      Power Loss (W)               142.3
      Motor/Gearbox Output (W)     501.7
      Output Power Loading (W/kg)  99.3
      Motor/Gearbox Efficiency (%) 77.9
      Shaft Efficiency (%)         69.5
      Motor RPM                    6151
      Propeller RPM                6151           actual-6700
      Static Thrust (g)            2921            actual 4100
      Pitch Speed (m/s)            26.0
      Run Time (min:sec)           8:27
    Flight Predictions
      Stall Speed (m/s)            10.7
      Optimal Flight Speed (m/s)   14
      Throttle for Optimal (%)     57
      Duration at Optimal (m:s)    54:46
      Motor Temp at Optimal (°C)   31
      Hands-off Speed (m/s)        16.7
      Throttle for Hands-off (%)   66
      Duration Hands-off (m:s)     41:50
      Motor Temp Hands-off (°C)    33
      Best Rate of Climb (m/s)     4.60
      Rate of Sink (m/s)           -1.22
    Note: Motor performance calculations take ambient temperature and heating effects into account.
    Generated by MotoCalc 8.08, 21/12/2012 17:25.
    Now getting 4.1Kg static with a 16x10 prop 6700rpm 44A 5cell.
  • Leo, how's the gimbal going?
    i'm now starting to use my plane for generation of mosaics, was thinking about a simplified gimbal, with about 20 degrees of freedom for each side on pitch and roll, just to keep the camera looking down. not sure if really needed, and its much more complex than just placing the camera down on the fuse, or even ataching it to the belly with rubber bands...
  • Just love CAD3692554700?profile=original
  • Interesting vids.
    It gets a bit complicated with belts. The only reason for the one I have is because I want to use a standard (not quite) servo and use a (32/20 teeth) step up to get a large rotation.
    Have just ordered a HS 5245 and programmer. This should then do 180deg and with the belt drive 288deg. Im trying to keep it all small.
    Am wondering about a shell/cover for the whole lot – complicated moulding.
    Perhaps I should start a new blog
     3692554755?profile=original
    3689488528?profile=original
  • Here's a link to the flight withe gimbal mounted on a sky walker...
    https://www.youtube.com/watch?v=ceca7eIGciw&feature=youtube_gdat...
