Firmware and Windows Client are made from a modified version of the orginal one found here : arducam-osd
Update 30 January 2013, new version include :
- Possibility to choose what parameter to tune with CH6
To enable this feature and display selectable parameter screen (screen 1) :
- motors must be disarmed
- CH7 switch is engaged
- Full throttle and full pitch
After you'll we see a check screen (screen 2) where you have to :
- Put throttle in low position
- Put pitch in middle position
- Put CH6 in middle position
Then you can select parameter (screen 3) to tune with CH6, those parameters are :
- STABILIZE_KP
- RATE_KP
- RATE_KI
- LOITER_KP
- LOITER_RATE_KP
- LOITER_RATE_KI
- NAV_KP
- NAV_KI
- Move pitch stick to move between parameter list
- Select with full throttle a parameter to be tune with CH6
- Quit screen and start tuning the selected paramter with CH7 switchin off position
After tuning a paramter, go back to screen 3, and save new parameter value with yaw stick to the left.
Compiled firmware : 20130129_ArduCAM_OSD_.rssi.time.status.climb.current.tuning.mavlink1.0.hex
Firmware sources : Arducam_osd_src.zip
Update 16 August 2012, new version include :
- Mavlink 1.0 support
- Flying time (count when throttle is above 20%)
Compiled firmware : ArduCAM_OSD_.rssi.time.status.mavlink1.0.hex
Windows client sources : OSD_IDE.zip
Update 23 May 2012, new version include :
- RSSI Display
- T° display (maybe useless :) )
- Climb rate
- Armed / Disarmed status (with Flight Mode)
- Speed in km/h
- No more "Charset update"
- Battery remaining (not tested)
"Charset update" was removed hardcoded, so to upload a new charset, you'll have to use the orginal firmware to do it and after you can use this firmware.
This new version need a new charset (MinimOSD_20.mcm) and the new client
Firmware : ArduCAM_OSD.rssi.amp.status.hex
Client : OSD_Config_RSSI_Status_Amp.exe
Charset : MinimOSD_20.mcm
RSSI is working with Arducopter 2.9.0 and above, but you have to disable COPTER_LEDS (set it to DISABLED) to make RSSI read working. Also don't forget to set your RSSI (8 for exemple) pin in MP.
Which versions of AduCopter supports RSSI? Looking back through the posts it looks like 2.60 worked from that point forward supported was dropped. Hopefully I wrong and some kind person can reply with the correct facts and clarify steps needed to enable RSSI on version 2.8.1 or above?
Many thanks,
I had a problem, solved now, to read RSSI from APM2. You have to change value of COPTER_LEDS, default value is ENABLED and you have to set it to DISABLED to make RSSI read working.
@Sandro Benigno thank you for clarifications, now it makes sense why it works with TX connected.
@Ovidiu, that isn't a problem with the firmware. Your APM isn't sending the data automatically. So, because of that you need to request data rates by a GCS or even by your OSD board. That's why it just works with TX connected. ArduPlane saves the requested rates on EEPROM (last request from a GCS or OSD). ArduCopter doesn't do that.
Check on MPlanner on Configuration >> Parameter List:
All the params with the prefix "SR3_" are related to this. E.g.: SR3_Extra1 = 5 means the IMU data being sent through telem port (serial 3) five times per second.
Much thanks also. That's great.
Thanks very much airmamaf
Much appreciated!
Post updated, it's available now here : OSD_IDE.zip
Got the source compiling ok now.
Is there also a zip file download available for the config tool source?
Peter
Yes, TX is connected for me. You can post a bug here for your problem : arducam-osd
