DIY 3 Axis 360° Rotaion Brushless Gimbal
3689550897?profile=original
I just spotted on RCTimer's new items page a new brushless motor for gimbals - GBM5208-SR.
What's good about it is that instead of normal shaft it has a tube shaft with a 12.7mm hole, they include a Slip Ring of the same size with it, this makes it easy to rotate 360° in all axis, for most people 360° rotation on the yaw should be enough. Also, due to the big shaft/tube size, i suppose the motor should be stronger, with a shaft like this and those big bearings applying direct weight to the motor should be no problem.
I already build a 3 axis gimbal for my Canon EOS M with the 4114 motors, now it's time to start prototyping Version 2.
My plans are to make it rotate in all 3 axis using the slip rings, they have 12 wires, which is enough for my project.
Here are some details:
Pitch Axis:
IMU - 4 wires
IR Remote Switch - 3 wires
Video Out - 2 wires
- Sharing GND and 5V it will be reduced to 6 wires only.
Roll Axis:
Pitch Motor - 3 wires
IMU + IR + VID - 6 wires
- So i use 6 wires for the IMU, IR and VID, i still have 6 wires left for the pitch motor, the slip ring is rated at 2A per wire, with the 6 wires i'll connect them in pairs to the motor, which i believe should give enough power to the motor.
Yaw Axis:
- This axis will hold the Controller Board and an Sbus Decoder. I don't want to add more weight so i'll use power from Aircraft main Lipo.
- With the Sbus decoder i will only need to pass 4 wires to the aircraft, which are GND, 12V POWER, VIDEO, SBUS SIGNAL. 2 wires for Sbus and Video, which leaves 10 wires, 5 wires for GND and another 5 for 12V should be ok i think.
- Yaw Motor and Roll Motor don't need the slip ring, since their leads are in the same axis, so i just can connect them directly to the Controller Board.
I can't wait to start this project, what do you guys think? Cheers!
  • Days have a similar brushless gimbal motor
    http://www.dys.hk/ProductShow.asp?ID=226
    They also have a 3axis gimbal, which you can buy with or without motors.
    http://www.dys.hk/ProductShow.asp?ID=220
    Rctimer also have a 3axis gimbal, with the GC included
    http://www.rctimer.com/product_976.html
    Im sure it won't be long till both companies are selling gimbals with the continuous rotation motors (the ones with sliprings) built in already.
  • Hi
    Thanks a lot.
    JM
  • Great find Sergio,
    I'd be willing to bet a lot more manufacturers will be following suit.
    Surprised the Tiger-Motor people hadn't already done it.
  • You can find a ton of slip rings on eBay, among other places. Very handy devices.
  • RCTimer includes the slip ring with the motor, but if you want just the slip ring alone you can try here: http://www.adafruit.com/category/34 they have several to choose from.
  • Hi,
    Do you known where to order Slip-ring?
    JM
