I just spotted on RCTimer's new items page a new brushless motor for gimbals - GBM5208-SR.
What's good about it is that instead of normal shaft it has a tube shaft with a 12.7mm hole, they include a Slip Ring of the same size with it, this makes it easy to rotate 360° in all axis, for most people 360° rotation on the yaw should be enough. Also, due to the big shaft/tube size, i suppose the motor should be stronger, with a shaft like this and those big bearings applying direct weight to the motor should be no problem.
I already build a 3 axis gimbal for my Canon EOS M with the 4114 motors, now it's time to start prototyping Version 2.
My plans are to make it rotate in all 3 axis using the slip rings, they have 12 wires, which is enough for my project.
Here are some details:
Pitch Axis:
IMU - 4 wires
IR Remote Switch - 3 wires
Video Out - 2 wires
- Sharing GND and 5V it will be reduced to 6 wires only.
Roll Axis:
Pitch Motor - 3 wires
IMU + IR + VID - 6 wires
- So i use 6 wires for the IMU, IR and VID, i still have 6 wires left for the pitch motor, the slip ring is rated at 2A per wire, with the 6 wires i'll connect them in pairs to the motor, which i believe should give enough power to the motor.
Yaw Axis:
- This axis will hold the Controller Board and an Sbus Decoder. I don't want to add more weight so i'll use power from Aircraft main Lipo.
- With the Sbus decoder i will only need to pass 4 wires to the aircraft, which are GND, 12V POWER, VIDEO, SBUS SIGNAL. 2 wires for Sbus and Video, which leaves 10 wires, 5 wires for GND and another 5 for 12V should be ok i think.
- Yaw Motor and Roll Motor don't need the slip ring, since their leads are in the same axis, so i just can connect them directly to the Controller Board.
I can't wait to start this project, what do you guys think? Cheers!
Oh that's right... forgot about the continuous part! lol TGIF!
Its cool to see brushless gimbal motors develop this way... hopefully they can do this with the smaller motors too. But my question is... if its got a hollow shaft, why do you need the slipring? I mean, why not just pass the wires through?
Hi
Thanks a lot.
JM
Great find Sergio,
I'd be willing to bet a lot more manufacturers will be following suit.
Surprised the Tiger-Motor people hadn't already done it.
You can find a ton of slip rings on eBay, among other places. Very handy devices.
RCTimer includes the slip ring with the motor, but if you want just the slip ring alone you can try here: http://www.adafruit.com/category/34 they have several to choose from.
Do you known where to order Slip-ring?
JM
