It has come to my attention that people are not noticing this amazing app that is being produced for Android to give full missionplanner functionality and more using Mavlink to your UNMODIFIED android device
sveD_QnMVCcbY90uEmIOO3LhAWSa2QuN69FFe-TkjavvWSL0gTW-7L_OdHUHL1ZI-w=h230
Features: Follow Me (If you device has GPS, you can set your plane or copter to follow me and it will circle or hover above your point or trail behind you as you run for it :)
Parameters (Droidplanner has a Parameters screen which allows you to correct your parameters in flight from your android device, no laptops to lug around!
Accelerometer Calibration Droidplanner has Horizon calibration to allow you to calibrate your copter in the field, which can be a life saver if you go miles to fly and find the horizon is off.)
Flightpath Planning  Droidplanner Offers the ability to program your way points onto google maps with options for default altitude and more, it is very user friendly and works well!
Remote control Aircraft from app.  (This app has a very special feature which allows you to Control your model from the app using a touch screen interface, this means if something went wrong and you could not use your controller, or you have a friend who wants to try flying but do not have a buddy system, you can use this feature to control your Model!)
Remote control Camera Gimble (A feature unique to Droid planner allows you to control a camera gimple plugged into the apm from the App, this means rather than buying two controllers or modifying your controller to add extra control for the camera, simply switch to camera control and you have full ability to adjust the camera position as you like.)
Live Horizon and Map view with telemetry data  Switch to the flight data Tab and have full telemetry view with vocal alerts, Altitude Number of sattelites, position shown on map, Airspeed and ground speed, level and more.
These are some of the Prominent features of Droid planner, but there is so much more!.
If you want to know how to connect the MAVlink dongle to your android device it is very simple, you need to buy a chep usb to micro usb (depending on your device) adpater from somewhere like ebay or amazon, plug the one end into android device, the other into the MAV link and thats it!
Check it out, completely FREE
https://play.google.com/store/apps/details?id=com.droidplanner
(update by mh)
You need aUSB OTG cable.
List of compatible Android devices.
(end update)
    Earl
    I'm going to receive a Nexus, when I get it I will implement Bluetooth.
    But for short range I recommend the Wifly module.
  • Mavlink 2-3KM range with stock antennas, Bluetooth 5-10 meters
  • how about a bluetooth implementation? one less dongle to have.
    Earl
  • This is not available for IOS devices, unfortunatly ios is a closed OS which means that you cannot use the USB device to wireless connect, and even if you could, the fees to host an app on ios are huge.
    I'm working in implementing this for the RC override control.
    But it's a great idea to do that for the camera gimbal. I'll look into that as soon as possible.
  • Can you use the tablet's inertial system to control camera gimbal?
    It would be very interesting to implement this capability.
    @Josh Potter
    The app is mostly just to get info from what is happening with the drone. Typing in a touch screen sucks.
    @Hugues
    Mission planner has the option to use a USB joystick, so you can get even better support.
    @leopoldo
    No, just for android.
  • Do you know if same app for IPad was developed also?
