It has come to my attention that people are not noticing this amazing app that is being produced for Android to give full missionplanner functionality and more using Mavlink to your UNMODIFIED android device
sveD_QnMVCcbY90uEmIOO3LhAWSa2QuN69FFe-TkjavvWSL0gTW-7L_OdHUHL1ZI-w=h230
Features: Follow Me (If you device has GPS, you can set your plane or copter to follow me and it will circle or hover above your point or trail behind you as you run for it :)
Parameters (Droidplanner has a Parameters screen which allows you to correct your parameters in flight from your android device, no laptops to lug around!
Accelerometer Calibration Droidplanner has Horizon calibration to allow you to calibrate your copter in the field, which can be a life saver if you go miles to fly and find the horizon is off.)
Flightpath Planning  Droidplanner Offers the ability to program your way points onto google maps with options for default altitude and more, it is very user friendly and works well!
Remote control Aircraft from app.  (This app has a very special feature which allows you to Control your model from the app using a touch screen interface, this means if something went wrong and you could not use your controller, or you have a friend who wants to try flying but do not have a buddy system, you can use this feature to control your Model!)
Remote control Camera Gimble (A feature unique to Droid planner allows you to control a camera gimple plugged into the apm from the App, this means rather than buying two controllers or modifying your controller to add extra control for the camera, simply switch to camera control and you have full ability to adjust the camera position as you like.)
Live Horizon and Map view with telemetry data  Switch to the flight data Tab and have full telemetry view with vocal alerts, Altitude Number of sattelites, position shown on map, Airspeed and ground speed, level and more.
These are some of the Prominent features of Droid planner, but there is so much more!.
If you want to know how to connect the MAVlink dongle to your android device it is very simple, you need to buy a chep usb to micro usb (depending on your device) adpater from somewhere like ebay or amazon, plug the one end into android device, the other into the MAV link and thats it!
Check it out, completely FREE
https://play.google.com/store/apps/details?id=com.droidplanner
(update by mh)
You need aUSB OTG cable.
List of compatible Android devices.
(end update)
  • Hi, yes it works with Mission planner, Telemetry boards are 100% stock, I have 9 sets to choose from.
    The Telemetry does connect. Solid green lights both sides, then Mav Data is coming through, because Droidplanner knows when I arm and disarm, and the Battery voltage shows correct. But no AH, or other HUD info, and no other planner functions are available. ideas how to troubleshoot this? I can make a video and post it if it may help.
  • Arthur, I have a Samsung Galaxy Tab2 10.1 P5100, it connects but no HUD info is changing. What will need to happen for it to work on the P5100?
    @Michael: please see http://diydrones.com/profiles/blogs/looking-for-testers-new-mavpilo... for iOS App.
  • Awesome!  And Android tablets are dirt cheap on ebay but their battery life sucks in general.
    I'd love to know when an iPhone/iPad version becomes available.
  • Ok  so its a M7 tablet, Android 4.1.1, Kernel 3.0.13.
  • Hello, just one question: were can i found this "S3C USB HOST DRIVER" ?? because i can´t connect my 433mhz radio to my tablet. I have installed 2 or 3 applications to try to solve this but all of them report that this driver is missing, so i need some help. Anny link or something please. Thanks
  • Kevin, Is there a way I can get in touch with this person? thanks, Michael
  • Hi Arthur,
    re-install did work.I could have tried this at first,but i didnt see the wood for the trees.
    Thanks a lot for your quick help.
  • What kind of information do you need ? I can easily connect via my cell with Android 4.0.4 to droidplanner.
    If i try with my nexus with Android 4.2.2 , no way.
    If i start droidplanner with my nexus it just says" droidplanner was finished" and i can either click ok or send a report.
    So, it seems to me its just 4.2.2
    But as far as i know my fellow campaigners in here, i am sure we will sort this out.
    By the way, droidplanner is a real masterpiece.
  • Andropilot works allright
