It has come to my attention that people are not noticing this amazing app that is being produced for Android to give full missionplanner functionality and more using Mavlink to your UNMODIFIED android device
sveD_QnMVCcbY90uEmIOO3LhAWSa2QuN69FFe-TkjavvWSL0gTW-7L_OdHUHL1ZI-w=h230
Features: Follow Me (If you device has GPS, you can set your plane or copter to follow me and it will circle or hover above your point or trail behind you as you run for it :)
Parameters (Droidplanner has a Parameters screen which allows you to correct your parameters in flight from your android device, no laptops to lug around!
Accelerometer Calibration Droidplanner has Horizon calibration to allow you to calibrate your copter in the field, which can be a life saver if you go miles to fly and find the horizon is off.)
Flightpath Planning  Droidplanner Offers the ability to program your way points onto google maps with options for default altitude and more, it is very user friendly and works well!
Remote control Aircraft from app.  (This app has a very special feature which allows you to Control your model from the app using a touch screen interface, this means if something went wrong and you could not use your controller, or you have a friend who wants to try flying but do not have a buddy system, you can use this feature to control your Model!)
Remote control Camera Gimble (A feature unique to Droid planner allows you to control a camera gimple plugged into the apm from the App, this means rather than buying two controllers or modifying your controller to add extra control for the camera, simply switch to camera control and you have full ability to adjust the camera position as you like.)
Live Horizon and Map view with telemetry data  Switch to the flight data Tab and have full telemetry view with vocal alerts, Altitude Number of sattelites, position shown on map, Airspeed and ground speed, level and more.
These are some of the Prominent features of Droid planner, but there is so much more!.
If you want to know how to connect the MAVlink dongle to your android device it is very simple, you need to buy a chep usb to micro usb (depending on your device) adpater from somewhere like ebay or amazon, plug the one end into android device, the other into the MAV link and thats it!
Check it out, completely FREE
https://play.google.com/store/apps/details?id=com.droidplanner
(update by mh)
You need aUSB OTG cable.
List of compatible Android devices.
(end update)
  • @leopoldo
    I believe Apple does not allow remote control / drone control apps into the store. All ipad apps are OSS and require everyone to build and install the app using a developer account using their mac.
  • I'm unable to connect droidplanner to apm using APC220 but I can connect using xbees. I can also connect mission planner to apm using either xbees or APC220. Am I missing something?
    @Wessie
    Probably the version you have got update with a bug fix (since I have been very active last week).
    Thanks for asking them for the new categories.
  • Hi Arthur
    So after spending the entire weekend messing around and it not working for me, I tried it again now, and what do you know - It works!  Great work with this project. thank you for all your efforts! I will be testing my Y6 this weekend , cannot wait to try follow me, and the first waypoint missions. wish me Luck.
    PS. I have asked for both DriodPlanner and AndroPilot Categories to be created, should happen soon
    @Wessie
    So it seams that you have everything working except the HUD. Can you try to disconnect and re-connect while the ArduPilot board is powered. What are you flying (and what version of the firmware)?
    I don't know if I can create a DroidPlanner category on the forums. Maybe creating a DroidPlanner users group?
  • By the way, why is there no DROIDPLANNER category in the forums? Surely that would be a better place for support queries like mine?
  • Hi, yes it works with Mission planner, Telemetry boards are 100% stock, I have 9 sets to choose from.
    The Telemetry does connect. Solid green lights both sides, then Mav Data is coming through, because Droidplanner knows when I arm and disarm, and the Battery voltage shows correct. But no AH, or other HUD info, and no other planner functions are available. ideas how to troubleshoot this? I can make a video and post it if it may help.
    @Wessie
    Does it your system works with Mission planner? Do you have your telemetry board in the default settings?
    Does the LEDs on the telemetry board blink?
  • Arthur, I have a Samsung Galaxy Tab2 10.1 P5100, it connects but no HUD info is changing. What will need to happen for it to work on the P5100?
    @Michael: please see http://diydrones.com/profiles/blogs/looking-for-testers-new-mavpilo... for iOS App.
