3 MR60 Drone humour hour Posted by Hugues on July 28, 2013 at 7:15am My god they reproduceIs it bad doctor ? E-mail me when people leave their comments – Follow
I think you should try the same size props but more pitch on bottom prop that the top. Since the lower prop has x mph air being forced into it and the upper is in basically static air.
Evolution of Drones or the the addiction to drones , the cost also grows with it
@Digital, it is a spontaneous generation without father. That's scary isn't it ?
@Neil, Yes I have tested about 10%shorter props on top versus bottom. Results are clear:
-Hover total current with same sizes props is 70A
while hover total current with 10% shorter props on top is around 60A
-I have less vibrations in filming with shorter props on top than same size props
Naturally hover point is between 5% and 10% higher with shorter props (you loose some thrust obviously)
I find something about mr.red quite endearing
are you having luck with the shorter/ longer prop combination?
whats going on with mr.red's gimbal..
indeed blue one is stranded for now, waiting for his ESCs that were cannibalized by Mr. Red.
1
2
of 2 Next
