Hi, when i fly multirotors one of my main worries is to avoid it from crashing. Mechanically I've practically solved it because I usually fly an octocopter (motor, prop and ESC redundancy). My main concern right now is how to power the flight controller safely.
Initially I've connect all my 8 linear becs (in parallel) to my flight controller because I thought that if one fails, the rest would supply the required power. Later on I found out that a linear regulator may fail and may supply voltages higher than 5v and that would burn the flight controller.
A fuse is the easiest approach to solve this but I've read that sometimes it doesn't work well (fast enough). So i found the Crowbar Circuit.
So, i would use 2 linear BECs for redundancy and the crowbar circuit after each of the becs so in case it fails it will not burn the flight controller:
Another option:
I had the idea to use a switching BEC but i don't know if it's the best alternative. I've read that you cannot put 2 switching BECs in parallel because the voltage is generated in waves that may interference each other. So to solve this, one switching bec would be in use and if it fails, the backup switching BEC would take place.
The diagram for this is shown below:
If the SBEC number 1 fails, the Schottky diode would alternate to the SBEC number 2. I think that using 2 diodes would be better for the redundancy (i don't know if it's ok to do that). Could I use a relay instead of this diode?
What do you guys think? Will it work? Any idea is very welcome! ;D
Does anybody have the part list to do a crowbar circuit for the APM? I think it should supply 5v and 500mA, is that right?
Best regards
Thanks for the great explanation Thomas and Phil ;)
eduardo, thanks for the tip. I´ll use this SBEC. May be I´ll use together with a schottky diode to have some redundancy, i still don´t know.
Bernardo, this SBEC is verygood.
I am using some of this parts in my lanes.
Sometime i modify some resistors to change the output voltage.
Take care about the ESC BEC´s.
If you connect all ESC BEC in parallel without equalization network you will have problem.
One bec will work very hot and it can cook itself.
When this occur the input voltage will pass direct to output and across the double-diode burning you AP.
Some time a good designed AP is much better than some redundancy.
Phil P, thanks for the explanation ;) But isn´t the 7805 a linear regulator (no transistor)?
eduardo, that´s nice to know that =)
Could you recommend a good regulator?
I bought the following SBEC, do you think that´s a good option? There are lots of goods comments
http://www.hobbyking.com/hobbyking/store/__10313__Turnigy_5A_8_40v_...
What about using this SBEC for the main powersupply and the BECs from the ESCs as the auxiliary powersupply? Schottky diode would alternate between them.
Bernardo, i realy dont know way you are worried to used this kind of redundancy in rotor crafts.
i fly rotorcraft for years (more than 5 year) i never had problem with controller power supply.
Its more easy that you get a problem in speed controller / motor / propeller than with stabilization power supply.
I use this kind of redundancy only in my big planes.
BTW, i have 3 2.6m, 8kg flywing and never had problem with regulator.
PS: use only good regulators.
The problem is not if the output transistor cook itself but way it cook.
Never user 7805 or any other regulator like this in poarallel.
To use in parallel you need to put some resistor to equalize the output.
My english is very poor to explain way the output transistor cook when more than one 7805 is used in parallel.
I not remember where i view this info (7805 or lm317 detasheet) but it exist.
This kind of thing is from old school electronics.
Thanks Phil - the person I'm hoping to convince has even less electronics knowledge than me though, so I was hoping for the "Idiot's guide as to why you don't connect multiple BECs in parallel", a web page, or definitive post explaining it ;)
"Initially I've connect all my 8 linear becs (in parallel) to my flight controller because I thought that if one fails, the rest would supply the required power. Later on I found out that a linear regulator may fail and may supply voltages higher than 5v and that would burn the flight controller."
Can someone point me at some definitive info on why this is a bad idea? I agree, and know the theory, but there's someone I need to convince so really want something I could point them to and be done with the argument ;)
iskess, Rambo and Nick, thanks for the feedback
eduardo, i don't know if it was for me, but i'll use it with a multirotor
1
2
3
4
of 4 Next
