FMA no longer carrying Z sensors
I'm sorry to report that FMA is no longer carrying Z sensors. They ran out of existing stock and because their basic Co-Pilot doesn't require them, they won't be making any more. They will continue to make XY sensors, which the Co-Pilot does use, and those should be back in stock in a few days. We're currently exploring alternative sources for the Z sensors, but in the meantime, I suggest you buy them from Dean Goedde for $40 including cable (scroll to bottom for price list).[Update: Turns out that those may not be totally compatible (they're 3.3v and require special wiring to our 3.3v shield). Stay tuned....we're looking at other options.] [Update 2: Dean writes and says that they are compatible: "My Z head is 100% fine at 5V. The analog output will be 1/2Vdd for a balanced horizon view, and skew away based on tilt. After all, myself, FMA, and Paparazzi are all using the same components and design. The AD8551 OpAmp is being used in all 3 of our Z heads and is fine to at least 5 volts.]
  • T3
    so what is the decision here? for those of us without the Z sensor. Jordi are you making some available for purchase? offline is fine with me. I need this up and running as soon as I can.... ;-) it's for a work demonstration.
  • Chris, that's great! Hopefully by next year I'll be able to start a UAV project with an ardupilot. Keep up the great work.
    William, as we've discussed before we will migrate ArduPilot to an IMU by the end of the year. The current board is powerful enough to handle the DCM algorithm. It will cost more than the thermopile, but only about 40% more.
  • The FMA design is available in many places, like in the FMA patent and the paparazzi project. Reversing it is no problem.
  • The link I posted previously is for a "Atomic IMU 6 Degrees of Freedom". It has a Atmel ATMega168 so there's non need to process the gyro data. Sure in the long run re-designing the board will make sense, but what do you do with all of the current inventory? Hopefully Chris can make a PCB with thermopiles. Has the FMA design been reverse engineered?
  • I don't think it's an issue of cost William, I think it's an issue of computational power.
    The cost difference is questionable I guess, the raw sensor cost of IR vs IMU (in the UAV DevBoard) is around the same, but then it depends on what gyros/accelerometers you use.
    The ATMega's are only 8bit and the ATMega48/88/168/328 in particular can only do 20MIPS.
    IR makes the attitude sensing pretty simple, just 3 ADC measurements and a (relatively) simple equation for pitch, roll, etc. With the IMU (gyros) you need to do quite a bit more to compensate for drift and all that comes with using an IMU.
    The UAV Devboard is (from memory) 16Bit and can do 30MIPS, so has quite a bit more power than the ATMega's.
    To do it properly, you would really need a separate processor (on a shield possibly like you say), which really just brings the whole project back to where it started (in a sense) as that's what the ArduPilot Pro was.
    I think that the Ardupilot should just be converted to a 3.3v device (more common these days). Then you can use Deans sensors which are better than the FMA ones and "FMA Approved".
    Gary, Yes! Balloons > UAV's.
    As we both know, they also cost more, but are less frustrating (unless you build one) ;-)
    Don't worry, we only used some of fat boy's advice, we are using a proper basket!!
  • What about using a 3 axis gyro like the UAV DevBoard? Like http://www.sparkfun.com/commerce/product_info.php?products_id=9184 or you could make a shield with 3 gyros. This would also allow the autopilot to work at night.
    What's the cost difference between an IR and gyro solution?
    Angus I hope you did'nt go for build advice from bin boy Barrow ;-) (no he did a good job only joking) All I see Mr K junior doing these days is dancing!! Slightly OT sorry guys and girls, but balloons were around long before all the rest so we rule everything aviation and thats that!
    Oh yeah your right Chris, that was the one I meant. I didnt know they had discontinued that one.
    I know quite a bit of the cost of an Attopilot is what Dean pays to FMA for use of the XY patent.
    Guess we will all go IMU soon anyway.
    Brian,
    We'll probably start selling populated PBCs and thermopiles. Give us a couple weeks.
