FPV setup with raspberry Pi
3689553118?profile=original
After much chasing, and testing, I have found this to be an efficient way of getting low latency high quality HD video out of an Aircraft. The latency is around 0.4 seconds at worst which would be OK for an FPV with an APM doing the hard work.
I will continue to search for methods to drop the latency down further, but this is a lot better than the 6-12 seconds I was getting on my first attempts.
Any comment (with useful instructions) would be appreciated.
For the wireless link, I am using two UBIQUITY ROCKET M 900 with Australian ACMA approved firmware, at the base station, I am using a tracking (yet to built the tracker...) 1.5 meter long X and Y polarised Yagi, and on the plane, two RF Design flexible strip antennas, placed at right angles to each other.
but how you do that bit is up to you.....
the critical bit is getting the Raspberry Pi's to chat to each other.
I have tried to make this as user friendly as possible... good luck.
Setting up IP video for Raspberry Pi 1080p video (FPV)
You will need 2 B model Raspberry Pi's and 1 Pi Camera. (Element 14, or RS components)
Preparing your Raspberry Pi for first boot…
Follow the instructions at http://www.raspberrypi.org/wp-content/uploads/2012/04/quick-start-guide-v2_1.pdf
Install the prepared SD card in the Pi and boot.
Setting up your Pi
Connect the Pi to your router with a network cable.
On Start-up it will resize the FAT partition and present you with a menu.
Set your language, and keyboard layout.
Select Raspbian… then click install.
After this has extracted (will take a while….) it will reboot into the configuration screen (again will take a while for this first boot.)
The important things to change here are
  1. Enable the camera
  2. In advance options…..
    1. Set the host name (camera, for the camera end, receiver, for the viewing end)
    2. Memory split, set the memory for the GPU to 256
    3. Enable SSH ( will come in handy later, as you may need to talk to the Pi in the air.....
Then finish and reboot.
First login
Username: pi
Password: raspberry
Setting up the required programs for video streaming
Install the dependencies by running the following in a terminal:
sudo apt-get install mplayer netcat
cd /opt/vc/src/hello_pi
make –C libs/ilclient
make –C libs/vgfont
cd /opt/vc/src/hello_pi/hello_video
make
cd ~
Now repeat this for the other Pi….
Streaming…
First set up the receiver….
Ensure the receiver is connected to your network and run
ifconfig
after you press enter, you can find your ip Address.  Note this down.
Then run the following.
mkfifo buffer
nc -p 5001 -l > buffer | /opt/vc/src/hello_pi/hello_video/hello_video.bin buffer
the Pi will now wait for the feed.
On the Camera Pi
Ensure camera is connected to the Pi
Ensure Pi is connected to the network (you can confirm this with ifconfig)
(see instructions at http://www.raspberrypi.org/camera for how to connect the camera)
In the following command, replace the ip address with the one you just noted down.
raspivid -t 0 -fps 15 -o - | nc 192.168.1.85 5001
if all goes well you should be streaming 1080P video at 15fps with less than 0.5seconds of delay..
now add your wireless bridge between the two, and away you go J
This information has come from the Raspberry Pi foundation website, and other sources, tested and proven by myself..
    At 500kbs it is a bit slow for video, but could be good for telemetry...
  • Somebody have look on http://rpi900.com ?
    I've read an interesting info on magPî and this solution could be great for us ?
    3d彩图平特一码官网-3d彩图跑狗图首页
    本站是国内专业的送28-88快娱乐平台,16年专业为彩票游戏爱好者提供游戏,各种游戏玩法等603多款游戏,目前已拥有PC客户端、手机、网页、官网、网址、官网等多种快乐十分游戏方式可供选择。
    So far I have only tested short range, if you want NLOS then 900 is really your only option. If you have a look through the thread, you will see a few people who have used the Pi to send their telemetry to the GCS over wifi. Make sure you use a level shifter though.
    Phil
  • 300km
    Hi Phil
    I do have 2.4GHz RC radio.
    Can you confirm that you mean you can operate the 900MHz wifi link and 900MHz telemetry without problem.
    What sort of range have you achieved with it?
    I'm hoping to be able to go beyond LOS, so the telemetry is critical.
    That all depends, if you are running 433 radio gear, then 2.4 is fine, if you are flying line of sight, then 5.8 should be good, if there are obsticals, then 900 is good :)
    As far as telemetry, I haven't seen any issues with the 900's affecting each other, though the longer term plan is for the telemetry to also go over the wifi link.
    Phil
  • 300km
    I've been looking at setting this up. I've got the RPis streaming over my home wired network. Now I'm looking at a wireless bridge so I can get the camera Pi airborne. The local Ubiquiti dealer recommended a PicoStation M2 in the air and NanoStation M2 on the ground. That's 2.4GHz. Isn't that going to interfere with my RC radio?
    I don't remember anyone mentioning any interference concerns in this post. This 2.4Ghz system is still going to interfere with my 2.4GHz RC radio isn't it?
    The original post uses 900Mhz, but won't that interfere with the APM telemetry?
    That leaves 5.8Ghz, (which I see is what Canberra UAV used in the OBC12).
    Thanks Ilya
    They come from RFDesign.com.au. The UAV is at the office, I will post some pics when I am back from leave :)
    Phil
  • Hi, Phillip! The system that you assembled is wonderful!
    In your post you mentioned that you used a strip antennas on the aircraft.
    Can you give more information about them? What size they are? How they are placed on the wing? What material was used to manufacture them?
    It would be great if you posted a photo of this antenna! :)
  • Nice find Michael; i'm pretty determined to get out and do some range testing this evening...  Need to get some scripts worked out for both camera and receiver pi to deal with network dropouts.  Seem to be a few examples running around out there, so shouldnt be difficult...
  • might be some useful info in here too (?) -
    You know what they say about how several years in the laboratory can often save an hour in the library.
