Here a quick guide how to set up your Futaba T14
I use 2 switches
1st switch “SE” – 2 position switch
2nd switch “SB” 3 position switch
Switch “SE” – Master Switch “SB” - Slave
How it works:
Switch “SE” “UP” position switch “SB” select modes 1,3,5
Switch “SE” “Down” position switch “SB” select modes 2,4,6
Step 1 .To get the right min/max PWM output we first need to set the Endpoint of channel 5, in my case name of channel 5 is “ Aux 1”
Linkage menu > EndPoint (ATV) > ch5 Aux 1 Travel value 65% and 72% as showed photo
Step 2. Model menu >Prog. Mixes > select 1st mixing
Set Master “SW-E” and Slave Aux 1 , Value “Offset by X and Y +25%
To get "Logic " window:
Click second "On" ( after green "on" )
What's all, enjoy..
HOLA AMIGOS, ALGUIEN ME PUEDEN AYUDAR CON QUE RECEPTOR TRABAJA EL T14MZAP PARA CONECTAR PIXHAWK
Hi.
I recently update the software of my T14MZP to Editor Ver. 1.7.0 and Encoder Ver. 1.47. I think this is the last update available. After the update, I saw that, on power up, there is no options to turn off the RF output to, for example, perform a range check. Exploring this issue. I realize the following procedure to overcame this issue:
- With the transmitter off, put the throttle stick all the way up
- Turn on the transmitter
- After the screen lights up, we have a Warnig to confirm to continue
- Put the throttle stick in lower position and... that's it.
Frederico Fernandes,
happy to solve your problem ;)
Rate A & Rate B changed to 25%, it works!
Thank you Tamer advise. Would you mean Rate A & Rate B?
at futaba 14-18 MZ owners if it does not work try to increase both rates to %25 instead of offset ! this could be solve your problem.
Notice that my T14 had some different screens then Alex's so I updated the firmware.
Here are the instructions for anyone that is hunting for them.
http://www.futaba-rc.com/faq/faq-14mz-q864.html
I found the software updates easily enough off the main http://www.futaba-rc.com but the instructions were not directly linked from the same page.
Also, after the update, the radio no longer asks to be turned on or off at power up?
I will try and program the two switches with Alex's instructions next.
Thanks, Alex. I've posted that in the manual here.
