GTK+ based GCS
3689386766?profile=original
Overview
Ground Control Station is a GUI based on GTK+, the platform is a quadrotor developed several GTK+ widgets capable of display telemetry data. These widgets are made to look like to real flight instruments in order to allow easy feedbacks for the user/pilot.
Features:
-Input Device 3D connexion 6Dof Mouse form manual navigation
-Automatic mode GoTo (coordinate selected on map click)
-Comunication Socket streaming UDP
-GUI Compatible for any Linux machine with GTK+ (Debian Ubuntu ...)
-HUD with Artificial Horizon
-Incorporate GPS map show
-Suppoert mjpeg streaming for augmented reality HUD
-Telemetry control
-Hhow inertial data
-Compatible UAV client FoxG20
groundstation
The is the first version of the ground control station. In this version, the GUI is devided into 5 tabs. The first one showing the telemtry widgets needed. The second tab is quite the same as gpsd_viewer. The third tab provide an easy show UAV data, the fourth tab show the motor and battery status, and the final tab provide a set the comunication.
http://www.federicololli.com/GCS.htm
3689386789?profile=original3689386711?profile=original3689386591?profile=original3689386724?profile=original3689386862?profile=original
  • p.p.s. is designed for use with short-range helicopters and quadcoper
    the imu is
    http://www.federicololli.com/foxg20-IMU.htm
    Hi guys,
    yes,Acquiring images from a webcam on board autopilot(fox board g20 with arm9 cpu 400mhz http://www.acmesystems.it/foxg20/doku.php ),are sent via UDP,and finally appear in augmented reality in the UHD.
    is not yet completed but soon I post everything on a quadcopter,I miss the place the code of the augmented stabilization sistem.
    moreover, using a joystick as mouse 3d,
    http://www.3dconnexion.com/
    to manually control the UAV
    to not use google maps, but instead osm-gps-map
    when I tested and validated all code will insert new content and functionality.
    seeking collaborators to help me, it's really a lot of work ...
    p.s.(for now there is only the linux version.There is a small file to execute instructions in the package)
  • amazing! seems to be very usefull and user friendly!
    could u explain how toinstall it in arch or ubuntu?
    is ther any way to have embembed the live video from the aircraft?
    it would be nice to have a 3d model in a 3d map ,is there any way to integrate it to the google earth api?
  • It looks great.  Does it run on MacOS?
