These are pics of our team learning to fly FPV, playing with ardupilot....
3689414195?profile=original3689414306?profile=original3689414285?profile=original3689414406?profile=original
ArduPilot autopilot.
ArduIMU
Ardushield.
HappyKillmore GCS.
Xbee Telemetry. 900 mHz
RangeVideo TX and RX 1,3 Ghz
Homemade Pan tilt camera.
0.40 glow O.S. fp engine
Big nitro tank to fly 50 minutes.....
2.4 Ghz 1 watt amplifier.
Futaba 9z radio TX
Assan 2.4 TX and RX modules.
RangeVideo V dipole antenna.
    Are you using a separate GPS for Remzibi OSD or have you connected it to the ArduPilot board with Remzibi's ArduPilot  firmware?
  • Diego, very nice plane! This scheme is the most suitable for autopilot and FPV usage. It's very good, that it can fly for around one hour. What cruising speed it flies? I wonder to estimate the range of flight.
  • Paul, if you fly the original trainer and this UAV side to side, you will notice no changes at all, this one does as good as it was when i took it out of the hangar 9 box....!!!!! also, makes rolls and loops and inverted.......
    A difference is the really BIG space on the fuselage to install almost everything you may dream of installing on a UAV......... also have been thinking of a parachute!!!!!!    another difference is that the fuel tank is very big and goes in the center of gravity, so, empty or full, i almost can´t see any change on the C.G....
    I have estimated something like 55 to 60 minute fly time in this configuration, (there is space for a bigger tank or a second one to gain 25 minutes extra......)
    Taking of and landing is very easy, i will make a video of the live video feed from the plane so you can see how stable it is on the air.....
    The tail booms are ALIGN helicopter tails..................
    Take a new or old trainer, make the mods and i am sure you will enjoy it....
  • Thanks Paul, it is a big thing for me that you say that.
  • Teejay, i use ardupilot because mi APM is on the quad! But let me tell you, the ardupilot behaves really good.... next week will be ordering a pair of APM kits...
  • Osd is a remzibi one. This airframe is a.modified hangar 9 solo trainer the fuselage was redesigned to ease the equipment install.
  • Setup looks great. What OSD are you using for FPV? This is a similar setup I want to have (one screen for FPV and one for GCS). Nice job!
  • Cool airframe! I'd like to know more! Scratch build or kit? And what range do you get on the vid Tx Rx using the amplifier?Airframe finish looks very professional. And I love the ample space you have for electronics
  • Good to see there are some ArduPilot Legacy users still flying. What version were you flying on this?
