main_130b.gif?width=750
A special thanks to Max Levine for his fantastic work on the new instruments. The instruments and 3D model can be set to a "smooth" setting for those of you with processor to spare. This setting can be changed in the File, Settings, Instruments tab. For the best performance, do not select smooth for the instruments and don't select the 3D model instrument. Plus the turn coordinator is working much better now....
Download available here: http://code.google.com/p/happykillmore-gcs/downloads/list
This version also contains the ability to save the data files as a .HEX on binary protocols which will show the same data as what's showin in the serial data tab (plus time and date).
Plus there's a Vario tab at the bottom left for those of you searching for thermals.
Guided mode is ready. Connect to APM, click the Control tab and click Guided Mode. Then double-clicking on the map will set the waypoint.
New "text" versions of the instruments and status tab are now available as well as 3 pitch/roll/yaw instruments for those of you setting up your quads.
    Nice work Happy.
  • Big likey!
  • Sweet mother of Jesus. Lovely work Happy.
  • Many many thanks for implementing the vario.  This is going to make this summer's flying a whole lot more interesting.  Definitely worth an extra donation :-)
    Gorgeous! For those who don't know Max's work, he's also done many of the diagrams in the APM and AC2 manual. Along with Sandro Benigno, who did the 3D renders, he's our graphic design god.
  • WOW!!! Looks great! Thanks for all the hard work you put into this.
