A special thanks to Max Levine for his fantastic work on the new instruments. The instruments and 3D model can be set to a "smooth" setting for those of you with processor to spare. This setting can be changed in the File, Settings, Instruments tab. For the best performance, do not select smooth for the instruments and don't select the 3D model instrument. Plus the turn coordinator is working much better now....
Download available here: http://code.google.com/p/happykillmore-gcs/downloads/list
This version also contains the ability to save the data files as a .HEX on binary protocols which will show the same data as what's showin in the serial data tab (plus time and date).
Plus there's a Vario tab at the bottom left for those of you searching for thermals.
Guided mode is ready. Connect to APM, click the Control tab and click Guided Mode. Then double-clicking on the map will set the waypoint.
New "text" versions of the instruments and status tab are now available as well as 3 pitch/roll/yaw instruments for those of you setting up your quads.
KnutL, can you email me your .hko file? happy at happykillmore dot com
Don, I'll do some more testing. I am not aware of a unicode problem.
Thanks Kirll, I know that offline mapping has been an ongoing request. I just haven't found a good solution that meets the license requirements of the maps sources.
Great, thnx. Did you change something in the area of displaying a data file ?
If I try to run a recorded (from the last version) .hko file, I cant see any of the flight data any more, neither in the instruments nor on the map. The only thing that happens is the voice output, eg. something like "Arrived. No heading to waypoint two".
In the serial data tab I can see mavlink data coming in.
Just wondering, does the new version support google.maps cache?
Thanks guys!
The more I mess with the Vario stuff the more I'm realizing this needs to be in it's own thread. It's getting bogged down with parsing the data and drawing the instruments. It can't fire the midi play event anywhere near as fast as it should.
