Hobbyking has done it again and have gone that step further.
500mw telemetry modules for amp/px4 and pixhawk is a reality.
Features:
• Interchangeable air and ground 433MHz modules
• Micro-USB port
• 6-position Molex connector
• 500 mW maximum output power (adjustable)
• -117 dBm receive sensitivity
• SMA connector
• 2-way full-duplex communication through adaptive TDM
• UART interface
• Transparent serial link
• MAVLink protocol framing
• Frequency Hopping Spread Spectrum (FHSS)
• Configurable duty cycle
• Error correction corrects up to 25% of bit errors
• Open-source SIK firmware
• Configurable through *Mission Planner and *APM Planner
Specs:
Supply voltage: 3.7-6 VDC (from USB or Molex connector)
Transmit current: 500 mA at 27 dBm
Receive current: 25 mA
Serial interface: 3.3 V UART
Included
Two radio modules with antennas
Micro-USB cable
Android OTG adapter cable
6-wire Pixhawk connector cable
6-to-5-position APM and PX4 connector cable
Self-adhesive patch
will the Pixhawk provide 500ma ?
@Jonathan. Can you recommend your favorite 915MHz antennas?
If you compare the module layout to a standard HM-TRP module you'll find that there are at least 2 extra chips. I wonder what those are.
The drotek model appears to be a standard HM-TRP, and it looks like there might be another module on the back, but the model on readytoflyquads looks like a different module, and the module appears to be clearly connected directly to the antenna, which means there is no extra PA/LNA.
There probably is a PA and an LNA on-board.
Into a mismatched antenna 500mw just generates heat.
I've never heard of, nor can I find any information on a HM-TRP with 500 mW output power. In looking at some of these pictures, it looks like the module is connected directly to the antenna, so I don't think there is an additional PA. Also, the module looks different than the 100 mW HM-TRP. Does anyone know what module these devices are using?
http://www.readytoflyquads.com/3dr-radio-telemetry-kit-915mhz-532
$45
I am particularly glad on the 433mhz 500mw and their price.
@Martin Drotek might be first to have it but you cannot beat hobbykings price.
1
2
3
4
5
of 5 Next
