HobbyKing is now selling much cheaper versions of some 3DR products:
(*This is an update of my old post which only referred to the two products available at that time.)
The latest addition to the list is especially well-timed because the 3DR Radio Telemetry Kit is currently out-of-stock, making HK the only place to get this item at any price right now. This could bring a welcome change to the tone of the DiyDrones Twitter feed as buyers stop venting their frustration with shortages and simply buy elsewhere.
HobbyKing changing strategies?
Even as HobbyKing is adding more ArduPilot accessories, the MultiWii and MegaPirate autopilots which they were selling are now being liquidated or have already been removed from the site entirely. It is easy to imagine that this pullback is the result of the rather infamous support nightmare they suffered when the entire run of MegaPirate boards shipped with an unworkable voltage regulator installed.
This shift in autopilot lineup could mean that HobbyKing has decided to get out of the autopilot business, sticking with accessories and staying away from complicated autopilots which have so many parts that can fail. A more likely explanation is that HobbyKing just wants an autopilot solution that works, and they're clearing the shelves to make room for something else, maybe ArduPilot, but probably DJI.
Personally, I like to imagine that somebody at HobbyKing is a rabid ArduPilot fan who clones a different 3DR part every time 3DR goes out of stock, just to make sure he can always get his fix.
Your ideas?
Last time I posted on this topic, I was expecting a rather dry discussion of the effect of clone manufacturing on the 3DR business model. That suggestion was rightly ignored, so this time I'll just ask: Do you plan to buy any clone hardware yourself?
For myself, I think my next purchase will be a 3DR PX4 with HobbyKing's telemetry and GPS. Frankly, buying the autopilot feels like enough of a donation to the developers without paying double for the accessories, as well.
I`m going to hang in with the originals,without the developing there`s nothing.
Andrew, I agree. I really wish we saw more innovation instead of simple cloning. There's lots of room for improvement. It would be really great as you say to have the telemetry and OSD built right onto the board, or rather, a daughterboard. Heck, add to it a receiver module. One problem with this is that it means you'd have antenna(s) on the APM which could be an issue if they are of the "rubber duck" type. But if they were the wire type, such as used on most Rx, it's not a problem. FrSky uses replaceable antenna, there's just a little connector on the board.
Something else I'd really like to see is a really robust post supply system. Not just voltage and current monitoring, but a dual supply for the APM with automatic switchover. This means that the system starts to get stacked sort of high, but then the mass would actually help with vibration. And the more wires we can eliminate, the better.
I'd also like to see machined aluminum cases with a well designed vibration damping system.
I look at things like the Ruggeduino as being a great example of open source innovation rather than simply cloning. "More expensive than an Arduino, but cheaper than TWO Arduinos."
http://diydrones.com/forum/topics/hobbyking-selling-cloned-3dr-radios
Hi Nathaniel, as requested I am reporting back after testing the board. It works very well, provides a 5v feed where expected and seems very well made. HobbyKing rocks :)
Rather expensive box on GLB.. Maybe they finally realized that they cannot sell stuff so cheap :)
http://www.goodluckbuy.com/protective-case-cover-for-apm-2-5-flight...
Interesting discussion. I think some people here have a misguided sense of what open source is. All the products, software and hardware are results of open source collaboration. As such the designs are supposed to be shared by everyone. So there is not such thing as a "clone" of APM hardware.
The fact is that Chinese companies are very good at mass producing hardware, and they help us hobbyists get hardware to play with at a very reasonable price. The majority of Arduino boards out there are manufactured by Chinese companies. If it was left up to "authorized dealers", the Arduino phenomenon would never really have taken off. As a basic 328P based Uno would probably cost over $100.
I don't agree with the assessment that the Chinese are unethical, and send out broken product to try to trick us. I buy stuff from Chinese companies on ebay, and hobbyking all the time. Whenever there has been problems, I either get a refund or replacement product. As a former supply chain PM, I am well aware of the problems of products getting out to the public with defects. The reality is that when you sell a $60 controller for very low margins, unlike expensive cars, there just isn't a good way to issue recalls. The best you can do is issue a refund , replacement or instruct the users on how to bypass it.
One has to make a choice, do we want expensive customer service management systems or do we want cheap hardware for hobbyists to play with, and sometimes need to tweak? Since I am more technically oriented, and don't mind tweaking, I prefer the latter, so I can get equipment to play with. Others who are not so technically oriented may choose the former.
However that we need to keep in mind that what we are doing here is bleeding edge stuff, and may not be suitable for the regular consumer, who just wants a toy to fly around with. I recommend they buy a small toy helicopter for $60, also made in China, and avoid the pain.
Thanks, for the correction, Jani. I should not have included your company in point #2. (Although the reality actually supports the point I was trying to make, I think.)
Since you've been in this for longer than any of us, are their any more details you can provide? I'm sure the early history is fascinating.
Jonathan, just to correct. jDrones and 3DR are two totally different companies owned by different people. I am owner of jDrones, Chris/Jordi (as far as I know) are major owners of 3DR.
jDrones never located in USA continent, we have always been here in Thailand/Bangkok (and I am a Finnish person).
Yes both jDrones and 3DR are working on this main project and we are initial creators of all ArduCopter and it's related parts.
This thread seems to be attracting a lot of nationalist comments. I've been removing the most egregious examples since page 1. If I have culled some vitriol/commentary too slowly/quickly, I apologize.
I offer the following replies to the comments I've deleted:
2
3
4
5
6
of 8 Next
