Hokuyo Laser Range Finder needs a home
3689493615?profile=original
I received a 2D laser range finder from the good people at Hokuyo more than 1 year ago.  My plan was to try to use it to improve ArduCopter's altitude hold or collision avoidance but other priorities have taken up my time and it has ended up sitting in it's box all that time occasionally making me feel guilty so I'm giving it away!
It's a fairly expensive sensor I believe (>$1200), beyond what most people are willing to spend for a diy project but universities seem to use them regularly.  Some specifications which can also be found here:
    sensing field of 240 degrees
    range of 6cm ~ 10m with 1cm accuracy
    completes a full scan in 0.1 seconds
    Serial or USB interface
    500mA power consumption
    160g
Ideally I'd like it to go to someone who can do the following:
  • build an arducopter library to communicate with the sensor.
  • incorporate the sensor's output for altitude hold or object avoidance.  This would likely involve:
    • adding a new throttle or roll-pitch mode to the main code
    • if used for object avoidance, adding a new PID controller to allow setting the response to objects sensed
    • adding a new parameter to enable/disable the object avoidance
  • perhaps most importantly you must have the time and desire to see the project through (something that I clearly failed at!).
By the way, this free sensor comes with free advice from me to help you overcome any code problems you face.
So if you're interested in this sensor please email or PM me and if you've got a better idea of how to use it than what I've written above that's also great!
I imagine a few people will want this sensor and I only have one so apologies in advance for those deserving people that I might not choose!
  • As the none to quick recipient of this sensor, I feel I should chime in here too.
    I have gotten the sensor up and operating on a PC and made a few determinations.
    For the original intention of possibly using it as a AGL Lidar it could be made to work but is inappropriate for quite a few reasons.
    It is quite mechanically sensitive and would be very easy to irreparably damage in even a minor landing (mishap).
    A simple laser altimeter that is not scanned is actually much more appropriate (and cheaper) for altitude determination such as this one: http://diydrones.com/forum/topics/lightweight-low-cost-laser-altime...
    Range is also too short, especially outdoors in full sunlight to be useful for an altimeter (practically less than 4 meters).
    It could be conceivably useful on a multicopter for obstacle detection and avoidance, but it's real value because of it's range, mechanical fragility and other limitations is on a ground vehicle such as an ArduRover or Robot.
    In that regard;
    I am now constructing a 2 wheel hanging pendulum robot utilizing brushless bicycle wheels which will incorporate both the laser scanner and a Kinect structured light device. However, initially at least they will both be connected through an on board PC which has both the existing software and sufficient performance to permit them to provide useful data.
    Initially I will be using an APM as the control system as it has sufficient easily accessible IO which the PX4 does not, but I will be converting to the Pixhawk when practical and it is quite feasible that the Pixhawk will have sufficient performance and memory facilities to permit the direct extraction of at least sense and avoid and possibly SLAM directly from the laser scanner.
    The Hokuyo scanner and Kinect will be mounted on a roll pitch stabilized brushless gimbal.
    The x scanning Hokuyo will also be independently and dynamically y scan-able providing an adjustable scan grid.
    I am assembling the robot chassis now and will be presenting a Blog for it at each stage of it's development.
    Randy, I am sorry I had not gotten back to you sooner, but life, the wiki and getting going on the robot have taken a bit longer than expected.
    I do expect to have the chassis together within a few weeks now though and I think you will be impressed.
    It is sort of at the other end of the spectrum from Jason Short's lovely little self balancing robot, more at the Mac Truck end of things.
    Maverick,
       The sensor is long gone!
  • Hi there, I am currently working towards an Indoor Navigation Project with the Arduino Board. Due to a shoe string budget, my school can't offer us such technology to program it. My team and I would be keen to take up this project and work towards the goals you have listed above. Perhaps we could discuss this? Plus you mentioned that you could advise us on programming which would be a plus point to us.
    Zhang,
         I guess that's possible and I can see why you might choose that method - because it allows you to treat arducopter as a black-box but then you won't have a GPS anymore and it seems like a very indirect solution.  If it were me, I would create a new roll-pitch mode that allows you to pass in desired roll and pitch angles from the gumstick .. or perhaps make the arducopter talk to the gumstick using i2c or SPI and then put the object avoidance code inside the main arducopter code.
    Ok, it's been given away.  It took me a while and I'll blame it on the trials and tribulations of the 2.9/2.9.1 release.
    It was a very tough choice which is also why it took me so long to decide.  In the end I picked the one who gave the most detail on what he/she knew about the sensor, the issue and what they were going to do about it.
    I wish I had more than one to give away!  If you weren't the winner at least take heart that the sensor is going to someone who will put it to good use instead of sitting in my drawer for another year!
  • Hi John, I Researched the Neato vacuum a bit and found out it also has a 4 meter range and similar resolution to the Hokoyu and it works for a full 360 degree circle. It has been hacked and looks like a very simple interface. I think this could be an excellent tool for Multicopters for object avoidance and for mapping. You can pick the entire vacuum up new on EBay for just over $200.00. I don't know the weight, but I am definitely looking into it. Thank You for mentioning it.
  • Small correction, from looking at Hokuyo Specs, I think it looks more like 4 meter maximum range.
  • I periodically lust after one of these for my RC car. They're the cheapest (still expensive) 2D LIDAR system out there (besides the Neato Robotics vacuum).
    It's a RS-232 interface and thus will require level converters to communicate with the APM. The communication spec is here if anyone wants to take a look:
    http://www.hokuyo-aut.jp/02sensor/07scanner/download/products/urg-0...
  • Hi Randy, I've actually been looking at scanning LASER rangefinders for some time for robotics use.
    This particular one sells for about $2500.00 although they have a similar one with a little better range for about $1200.00 with the designation UGO1 after the model number. This particular one is also listed for indoor use only so it probably should have a supplemental enclosure built for use outside in less than perfect weather.
    Although it has reasonably high impact and vibration resistance, in use these things need to be well insulated from vibration as it can generally screw up their scanning mechanism.
    While I am sure you could use one of these for simple altitude reporting they are really designed to be an obstacle detection or scanned image producing device at which they excel.
    In the case of a multicopter you have an excellent (moving) platform for producing a scanned distance image which can provide immediate and accurate mapping data of it's surroundings (see University of Pennsylvania mapping copter. The other (and complementary) means of doing this is with an infrared 3D camera such as is used in the Microsoft Xbox Kinect and is what I am currently working with.
    My personal feeling is that this should be interfaced to provide scanning and mapping data rather than simple altitude and I am not sure that the APM has sufficient leftover bandwidth to be suitable for this task. A simple non-scanning and much cheaper laser rangefinder would be more appropriate as an altimeter and there are some assorted conversion projects for these that can be found on the web.
    I would be willing to undertake interfacing this to the APM as an obstacle avoidance and/or distance imaging device.
    I am a retired electronics engineer who designed microcontroller hardware and software systems. Although I am more familiar with Microchip PIC designs and programming I have been working with Arduino and Android projects since I retired and have lately been working to familiarize myself with Arducopter / plane source and development system. I am a solid hardware design engineer with fair to good capability in Assembler. C, C++ and Java for microcontrollers. Depending on how a straight APM interface worked out, I might elect to interface to a separate microcontroller board (Arduino or Android to offload imaging).
    This is not a small project and I would definitely need your assistance with the Arducopter software. At least two of my Quadcopters can support the 6 oz or so  of this device.
    If there is someone already qualified with the Arducopter software who wishes to undertake this project please jump in there.
  • Randy will be helpful if you can just hook up the sensor and give us what information you can read :) I haven't checked on internet about this sensor but maybe I can find a documentation about the protocol
