Here is my connection (You can check GPIO pinout here):
I used theFTDI GPS adapter cable, solder pads can be used also, just have in mind the TX pad = RX Ublox and RX pad = TX Ublox.
To get information from GPS in the Raspberry Pi (RPi), we will use gpsd.
Open a terminal
Install gpsd:
sudo apt-get install gpsd gpsd-clients python-gps
Setup RPi UART:
sudo nano /boot/cmdline.txt
delete the "ttyAMA0" parameter to have:
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
sudo nano /etc/inittab
comment (add a hash #) the line below "#Spawn a getty on Raspberry Pi serial line" like this:
#T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100
Reboot the RPi to apply the configuration:
sudo reboot
At this moment gpsd program is installed. If any gpsd session is open, stop it by:
sudo killall gpsd
Due to 3DR GPS is configured at 38400 bauds, set the RPi to 38400 bauds will be needed:
stty -F /dev/ttyAMA0 38400
(when RPi reboot baud rate returns to default)
Start gpsd:
sudo gpsd /dev/ttyAMA0 -F /var/run/gpsd.sock
Display GPS data:
cgps -s
When 3DR GPS is fixed, the fix blue led will be blinking and you will get the data like this:
If the GPS is not fixing, try outdoors where you have a clear sky view.
Yep that worked well, thanks for posting
hey guy's i have a question about this post, is normal the values of latitude longitude and other , have a value variance when the GPS is moveless?
I love seeing people into raspberry into 3DR gear! Raspberry is what many of us start out using when we first get into robotics.
