Previously, I introduced how to spray with Manual Operation Mode and A-B Route Operation Mode. Today, I highly recommend you use the more intelligent operation mode —— fully auto operation mode. It can plan route and avoid obstacles accurately. However, you should set blocks, measure and plan it in advance, which requires more preparation. Taking the Z series holistic system as an example.
Step 1.Click Agri Assistant >Connect> H12/MK15 >Ground Plan > New Plot.
Step 2.Select the planning method①Handheld GPS(RTK point device) ②Flight GPS ③Map Selection ④Waypoint planning. Method① and ② are widely used.
Step 3.Set Ground Name, move the handheld point device or fly the aircraft to the field, click the Boundary Point on the right side of screen to add dots in turn.
Step 4.About obstacles, move handheld point device or fly the aircraft to the obstacles, click Obstacle Point. There are two methods to mark it, Polygon barrier point and Circle obstacle area. Note that if you select Polygon barrier point, use the Boundary Point to dot. Handheld RTK point are recommended.
12144466498?profile=RESIZE_710x
Step 5.Click “Save” after all operations are done, tap on the left, select the newly saved plot, click Share > Confirm, the plot information is listed in Block Data.
Step 6.Tap, select the plot, adjust the route and click “Start”, then check the parameters according to prompt. Click Confirm and Slide Right Start to take off.
You can select the desired mode for spray according to the application scenarios. What kind of work mode have you used? Welcom to share your opinion.
*The above steps are for reference only.  Please refer to product use manual when using.
