"Hyperspectral" GoPro HD
3689413813?profile=original
GIF of my close with filter options
As you all know I've been bashing away to create code for cameras whether that be tracking a GPS point or stabilising the camera platform or just clicking the camera button. The code is currently adolescent in nature, everything is in there it just needs wisdom to match the knowledge. This brings me to my own camera, the GoPro HD.
Many here have one as well as a few more thousand around the world. They are great cameras for recording everything we do from FPV fun to scuba diving but hacking them is pretty hard (as shown by the guys on the GoPro forum trying to get the connector to play nice). One of the reasons I bought mine was because it does 1080 video and is pretty small making it great for my plane and quad and anything else I feel I should record but more importantly it is IR sensitive.
Disclaimer: In doing anything mentioned in this blog post or reponses below you are taking responibility for your own actions. DIYdrones nor myself take any responsibility what you do.
Oh no GoPro glue down the lens so you cannot get it off :O That stopped me for about 15 minutes while I googled. YouTube to the rescue. I removed the lens as shown in the video using this grips below (yes that is heatshrink 22mm is not really big enough). This is only half the problem though as the lens contains an IR filter so how do you get out the IR filter? The IR filter is held in place in the bottom of the lens by a thread O-ring of sorts (bolt with hole in it, see below) and because of the gap between the slots (the focus path) what in the jesus could I use. I went to my toolchest (yep chest and still didn't have the right tool any flat head screwdriver the reached both sides was simply to thick so what did I do :D That is right, the picture below shows my bodge. I filed a claw hammer I have to the correct width (9.5mm) and then filed the thickness of the "claw" down to fit inside the slot. Not only had I created a flathead screwdriver but because it was on the hammer I had control over the lens pressure rather than screwdriver pressure when I used it making it less likely for me to injure myself or the lens. I suggest that anyone trying this turns the lens rather than the screwdriver too. There is a little glue on it too so give it a poke with a knife. Once the filter is out screw the "O-ring" back in so it will be safe if you want to return the lens to normal again. Do not reassemble everything just yet, turn on live feed and plug in to the TV preferably over HDTV and focus the lens again. Be warned even with the thread lubricated it is still a patience testing moment but be steady. Once focused you can put it all back together again.
Filtering the light that reaches the sensor is up to you and your choices.
The gif above shows how the picture changes with the filter options I have used so far. I had a video camera visible light filter but in trying to install it broke it so I'll try to find another and adapt the housing to it (as during using live feed it was WAY better than the examples here). Not sure of the uses to be honest yet but night and day recording without worry is kind of cool. I will add a video timelapse of my street as the sun sets to show the difference in light with no filter later on
3689413824?profile=original3689413913?profile=original3689413926?profile=original
You will see me standing the middle at two points of the video. Once at 9:25pm (sunset) and again at 11:34pm. Gives an idea of the performance.
  • I am in the UK in Wiltshire. I filed down my glass filter that I broke and stuck it in the lens (why the IR picture in gif on main blog post has blurry patches at the edge splintered glass). I have also found that the filter was 9mm the opening in the lens was 8.5mm
    I'd love to see the extent the image sensor can deal with by comparison but I do not know anyone with any such thing.
    Took a timelapse last night with the new IR pass filter (glass one I filed down) and suspect it removes 99% of visible light because once the sun goes down all I see are light bulbs :D
  • nice update,if you has spectral Instrument,use spectral data Compare you GOPRO images,may be you can find more interesting tihings.
  • No no Jonathan that was the holiday watering from my mother. "You had weeds dear so I put that weedkiller on it".
  • 3692229065?profile=originalThe macro is clearly setup for the absorbance of the Canon as you can see the that plants are darker while buildings are lighter. I'd guess some tweaking would make it work ok though its just like arduino code so would be easy. Picture is a gif
  • Just updated the gif at the top as I have filed down the glass IR pass filter I broke to fit inside the original lens like the IR block filter I removed. Significantly better.
  • Nice to see some Multispectral and Hyperspectral stuff but its still way out of reach for the DIYdrone. Also nice to see the actual technology on the techexpo site showing one focusing system but two imagers connected.
    With another GoPro and qualtiy lens I think you could achieve a moderate setup with some post-processing for channels are such.
  • nice work, I am working on remote sensing. and i have a real Hyperspectral--ASD FieldSpec
    this is some commercial Hyperspectral:
    http://www.tetracam.com/index.html
    http://www.techexpo.com/WWW/opto-knowledge/products.html
    may be help for you
    Tetracam Multispectral and NDVI mapping Cameras
    Tetracam Multispectral Camera products site
  • @Luke Lee is much cheaper but I'd rather have glass but it could serve whilst I source the glass at least for that price.
    @T.D. It was dead easy for me
    @Kryzsztof Yes I'm searching for an 8mm IR pass filter to replace the IR block filter that is standard. As for rainy days I won't be flying xD SAR will go through any cloud though and that is yet another of my "in progress" projects (long way from putting it in the plane though antennas are 85mm dia by 175.3mm in length hardly Easystar size).
  • T3
    Check if it will be focused at infinity. I am afraid it won't until you replace the filter by glass of something.
    Second problem (and a serious one) is that no matter what filter you put on, rainy day stays rainy day.
  • Nice. At some point I'm going to need to do something like this.
