Introducing the PX4 autopilot system
The PX4 team is pleased to announce early availability of the PX4 autopilot platform, with hardware available immediately from 3D Robotics.
px4fmuv1.6_top.png?width=400
The platform is a low cost, modular, open hardware and software design targeting high-end research, hobby and industrial autopilot applications.
PX4 is an expandable, modular system comprising the PX4FMU Flight Management Unit (autopilot) and a number of optional interface modules.
The PX4FMU autopilot features include:
  • 168Mhz ARM CortexM4F microcontroller with DSP and floating-point hardware acceleration.
  • 1024KiB of flash memory, 192KiB of RAM.
  • MEMS accelerometer and gyro, magnetometer and barometric pressure sensor.
  • Flexible expansion bus and onboard power options.
Expansion modules available at release include:
  • PX4IOAR This module interfaces PX4 to the AR.Drone motor controllers, allowing a complete quadrotor to be assembled using an AR.Drone frame and motors.
  • PX4IO A flexible interface module with support for eight PWM servo outputs, relays, switched power and more.
As an open hardware design, third-party and DIY expansion modules can be easily developed for specific applications, and more PX4 modules are in development.
In addition to the versatile hardware platform, PX4 introduces a sophisticated, modular software environment built on top of a POSIX-like realtime operating system. The modular architecture and operating system support greatly simplify the process of experimenting with specific components of the system, as well as reducing the barriers to entry for new developers.
Adding support for new sensors, peripherals and expansion modules is straightforward due to standardized interface protocols between software components. Onboard microSD storage permits high-rate logging and data storage for custom applications. MAVLink protocol support provides direct integration with existing ground control systems including QGroundControl and the APM Mission Planner.
Pricing of the PX4 components reflects more than a year of careful development and a strong commitment from our manufacturing partner.
This release is targeted at early adopters and developers looking for a more capable platform than existing low-cost autopilots. With more than an order of magnitude more processing power and memory compared to popular 8-bit autopilot platforms, PX4 is exceptional value for money and provides substantial room for future growth.
For more information about the PX4 autopilot platform, visit the project website at http://pixhawk.ethz.ch/px4/
PX4 modules can be purchased from our manufacturing partner, 3DRobotics.
    to Dave_fr:
    DIY Drones is manufacturing and distributing the *hardware* on behalf of the "PIXHAWK" project.
    The nuts and bolts of the project can be found here https://pixhawk.ethz.ch/px4/
    The project has its own "software stack", which is based on an embedded RTOS called NUTTX, with a number of custom applications and tools designed specifically for the sensors and management.
    There are a couple of side-projects that are being worked on to port ArduPlane/Copter  to the PX4.  Once of them based on a "bare metal" solution ( porting ArduCopter32 to PX4 ) , and the other using the existing Nuttx OS, and porting ArduPlane as an "application".    Neither of these is anywhere near being workable at this time, and it's possible that we may not even persue  these to completion.
    As I understand it, the hardware/software stack is designed for *research* not as a turn-key solution, so don't expect any of the software to work "out of the box" ( although that said, some of it is getting very good)
    They are actually working very closely with the ArduPilot hardware peeps in regard to keeping the platforms as compatible as possible ( which is why there is a gps connector on the APM2.5 to match the PX4 connector type), and the software devs are working toward making the systems compatible on as many levels as they can.    As I understand it, the "stock" PX4 firmware already works well enough to ( a ) fly an AR drone ( b ) fly a quadcopter (experiemntal) and ( c ) fly a plane ( experimental) .....
    It also talks "mavlink" happily to qgroundcontrol, and will soon be able to speak to APM Planner happily as well (the fact it doesn't is a bug).
    Buzz.
    ( the guy who's crazy enough to try to port ArduPlane to PX4 as an app ) .
  • I'm just the minion working with the board. The guy who bought it is named Dan Block, University of Illinois.
    Thanks for the help, I appreciate it!
    Jan: I don't see any record of you having emailed sales or customer support. When did you send it?
  • It seems DIYDrones is incapable of answering emails in a timely manner, nor answer requests for an RMA.
    Let's go, either you tell me what the proper replacement parts are so that I can solder them onto the PX4IOAR, or you take the board back. But do either a little quicker!
    So, there are values given in the schematics for the two capacitors that need to be replaced. Are those values correct? Are the schematics up to date?
    Nick V, if you are comfortable soldering SMD chips, and voiding warranties, you can just do it yourself. :-)
  • the few that went out.
    the paperwork was inadequte - a special tax has been charged.
    plus no header for the xbee - neither a gps cable.
    it arrived today.
  • The website was quickly down due to a building power test and is back online. Sorry about the inconvenience.
    https://pixhawk.ethz.ch/px4/start
    The site was up this morn, so I suspect it's just a momentary glitch. I'll give the team a heads up regardless.
    As for the J9 connector, it (and the Xbee header) were inadvertently missed by the kitters in the first few that went out. They'll be shipped to you with the rubber spacers, which you probably already saw a note about.
    Me109: the Eagle files are now live in the product listings.
    https://store.diydrones.com/PX4FMU_p/br-pxfmu.htm
  • @px4
    that explains why the store has problems.
    but still, i ordered when there whee more as 30 units available. this was just a few moments after the px4 blog posting. and at the moment i paid but have nothing ... not even a message that the delivery is or will be delayed.
