Iris Details: #2 Injection molded arms and Legs
3689544079?profile=original
Here are some close-ups of the arms and legs. They are made from DuPont Zytel®, very strong and resilient in a wide range of temperatures.
Guillermo had some break force testing done, the results were impressive:
In the center it takes 204 lb (92.5 kg),  and at the tip  772 lb  (350 kg).
3689543968?profile=original
3689543993?profile=original
3689544154?profile=original
Sliding dovetail and set-screw retains the legs, allowing for easy replacement if needed. Picatinny rail mounting system integrated into the bottom of the arms provides endless mounting options for accessories.
3689544219?profile=originalMotor wires are protected, but not buried. Quick release clips keep things tidy.
  • Is the body and arms going to be available for us that have APM's and would like a snazzy body ?
    Earl
  • Evgenly,
    The ridges on the bottom of the arm are part of the quick release rail system, they are not there to increase strength.
  • ledges on the bottom of the beam is not added strength but increase the weight
  • Alexsey,
    No these are not compatible with the DJI products.
    Stephen,
    We are using these prop mounts because they are lighter and run true.
  • T3
    Very polished and professional looking.  Is that a new prop mounting system I spy?  I say that because I spy no collet.
    Where do the motor wires go, through that channel on the underside?
  • Plastic is always going to put carbon fiber out of business, once the volume of manufacturing is high enough to justify the molding.
  • NICE!
    Seems like legs are DJI compatible?
