.jpg)
The Quanum telemetry system gives real-time, accurate voltage display and low voltage warnings via a robust 2.4Ghz DSSS connection.
The receiver pannel is a large 132x64 LCD and attaches directly to your existing radios antenna for convenient at-a-glance in-flight voltage checks.
The Quanum Telemetry system will also warn you when your battery pack is approaching 3v per cell with a variable audio tone. No more deadstick landings!
And because its 2.4Ghz DSSS it wont interfere with your existing system, no matter what channel youre on!
The Quanum Telemetry system transmits a narrow, lightweight signal 4 times a second and uses DSSS technology to ensure no conflicts with other systems close by. Included is an inbuilt 450mAh Li-ion power source and a convenient in-car and PC USB charge jack!
Specification;
Tx Weight: 16g
Tx Size: 50x17.5mm
Tx Output: 20dBm <100mW 2.4Ghz DSSS
FCC ID: XR9V003
Tx Weight: 16g
Tx Size: 50x17.5mm
FCC ID: XR9V003
Included;
Large high contrast 132x64 pixel LCD 2.4Ghz Receiver.
1km Range 1~6S Transmitter
Receiver mount (universal type)
Cigarette lighter 5v out USB charger
USB cable. (Charge in car or on a PC)
CE, FCC, RoHS
I wonder if this could be hacked to tell us a little more on the ground, not in colour or hi-res obviously
Signs of things to come. Just thinking its probably useful in itself as a backup battery monitor on the ground.
If you fly 2.4 already, wouldn't this system possibly interfer with the 2.4 radio reciever in your plane? Isn't that basically the same limitations as using a 2.4 video link when you are running 2.4 radio gear?
To me it looks like good stuff and the price is good but only if you fly something other than 2.4.
@Thomas, what I feel is that It should work like just another 2.4GHz radio operating in your neighbourhood.
ect and sell expensive sensors.
