I would like to present to you a new BL Gimbal designed and build by KamKop Systems. The gimbal is available as a D.I.Y. kit and it includes all the frame parts needed to build the gimbal to fit Sony NEX cameras with SEL-16F28 or SEL-P1650 lenses. The gimbal consists of 6 machined aluminum plates, 3 GFK plates, a camera screw and couple of 3 mm screws needed to mount all the parts together. The gimbal can be adjusted on all axes and allows the mounting of the camera in the centre of gravity. Through the adjustable camera plate, you can use the NEX camera either with the Sony SEL P1650 lens or the 16mm pancake lens. The MPU sensor and HDMI / composite converter can be mounted on the plate above the camera. The gimbal is designed for RCTimer 5010 / 0.21mm / 150T or iFlight GBM4008 motors and the the AlexMos Brushless Gimbal electronics. The final product will be black anodized and available by the end of next week for less than 200€ bucks. Total weight without motors: 234 gr. Mount plate drill holes : 1. 110 x 128 mm 2. 75 x 130 mm Preview pictures are available at KamKop Systems kamkop.de But as I mentioned the final product will be anodized black!
Videos :
https://www.youtube.com/watch?v=TU3QNOn_UrY
Hi Peter email sent I look forward to your reply
the German Forum !
http://fpv-community.de/showthread.php?25914-Noch-ein-NEX-5-Alu-Gim...
the height is 170mm with no dampers !
Peter, can you tell about the overall height of this gimbal?
(How much space must a landing gear provide so this can be mounted?)
Thank you very much. As far as i am updated there isn't any 3 axis affordable gimbal controller. Does this mean your design will have to wait for such a release or will it accommodate 2x 2axis gimbals in order to achieve a 3 axis configuration? Or do you know something we don't? :D
the three-axis system will take about 2 months
Please visit the www.kamkop.de often to see the news
Do you have an estimated for the 3 axis gimbal? I would love to put my hands on one of them for ground shots and chasing scenes.
it does not matter which flight-controller is used
it is a separate system
we use the currently best BL gimbal controller
http://flyduino.net/Alex-Mos-Brushless-Gimbal-BLG
and these motors
http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=...=
or
http://www.fpv4ever.com/en/moteurs/1283-motor-mt2212-13-980kv-rc-ti...
Ship to Canada 36 Euro
it looks amazing. Have you tested it with the APM 2.5? How many mAh in that 3 cell battery?
I'm really interested in this gimbal, how much is it to ship it to Canada - Toronto?
thank you!
American kids don't play with Euro, it ;s too expensive...
