I don't know how long of a distance it takes for most of you to land, but when diving in below the treeline from 200 feet I pick up tremendousspeed on my EasyStar to the point of hitting 50 mph and overshootingthe runway, ending up in the trees.
Of course I can land in 500 feet easy, but making my autopilot do it wasnot. I was curious if anyone wanted to chime in on how they solvedtheir landing issues and minimizing the length of space required.
I was able to get mine down to 500 feet diving in from 200 feet and leveling off. The attached photo is my landing pattern.
1) Circle the landing zone, sample the winds
2) Go downwind
3) Turn for final approach
4) DIVE! with a feedback loop on airspeed able to do reverse thrust
5) flare and land.
My reverse thrust is done with a car speed controller. I can get +1 lbthrust as well as -1 lb of thrust. (Wasn't expecting that either.) Thisis just by running a typical 5x5 prop backwards!
The end result is that I slow down from 50 mph to 20 mph in a few seconds after the dive.
Landing patterns however, I think TJ is spot on but the landing area would have to be of a certain size in every direction. A setup I had considered for mission planner software was waypoint based. With a "string" of waypoints with landing point and approach start at either end. With two waypoints between to help you setup for a gentle plop rather than a splat. My worry now is that without getting the wind right (predetermined points), this plop will be much more likely to be a splat.
However, what if TJs landing preparation could be used to lay out the waypoints for my "landing strip" idea. The landing strip could have definitions to the airframe to become more specific and allow better control during landings.
Right now I don't have a rudder hooked up, but that would be a neat thing to try (slip).
I like to think of this experiment as trying to land in a canyon in hurricane force winds. Scale wise it seems to be exactly that. You want to keep that speed up until the last second!
Awesome suggestions! I have to say that the reverse thrust produces amazing amounts of breaking. Almost too good. I had to dial my gains back. The first try I stopped in my dive almost instantly and tip stalled.
Nathaniel
My goals are to have the shortest landing possible without adding equipment. No sonar, no parachute. And without adding more feedback loops. This algo seemed to be the ticket. Do you know if anyone (including yourself) has gotten what you suggest to work coming in from so high with only 500 feet of space to land in?
The purist in me wants to do altitude on throttle, airspeed on elevator 100% of the time. I just can't seem to get the same level of accuracy with that technique if you are trying to fly on beams between waypoints PRECICELY.
