I don't know how long of a distance it takes for most of you to land, but when diving in below the treeline from 200 feet I pick up tremendousspeed on my EasyStar to the point of hitting 50 mph and overshootingthe runway, ending up in the trees.
Of course I can land in 500 feet easy, but making my autopilot do it wasnot. I was curious if anyone wanted to chime in on how they solvedtheir landing issues and minimizing the length of space required.
I was able to get mine down to 500 feet diving in from 200 feet and leveling off. The attached photo is my landing pattern.
1) Circle the landing zone, sample the winds
2) Go downwind
3) Turn for final approach
4) DIVE! with a feedback loop on airspeed able to do reverse thrust
5) flare and land.
My reverse thrust is done with a car speed controller. I can get +1 lbthrust as well as -1 lb of thrust. (Wasn't expecting that either.) Thisis just by running a typical 5x5 prop backwards!
The end result is that I slow down from 50 mph to 20 mph in a few seconds after the dive.
Nathaniel
My goals are to have the shortest landing possible without adding equipment. No sonar, no parachute. And without adding more feedback loops. This algo seemed to be the ticket. Do you know if anyone (including yourself) has gotten what you suggest to work coming in from so high with only 500 feet of space to land in?
The purist in me wants to do altitude on throttle, airspeed on elevator 100% of the time. I just can't seem to get the same level of accuracy with that technique if you are trying to fly on beams between waypoints PRECICELY.
I found though in my tests that doing exactly what you describe was a bit more sloppy-- and didn't work very well at all in winds. Basically it took more landing space, had me on the edge of stall (and I'd get tip stalls on landing), and had me tweaking even more parameters for different PID loops on landing.
I heard that this was "wrong" but I find that diving in and leveling out winds up working in gusty winds and seems like a more controlled way to get down and lined up. Of course the bad part is that you're going too fast.
I always imagined having throttle blaring, nose up 15 degrees, with a gentle touchdown. In practice I was never able to do that without stalling alot. Maybe I was doing something wrong.
1
2
3
4
of 4 Next
