I don't know how long of a distance it takes for most of you to land, but when diving in below the treeline from 200 feet I pick up tremendousspeed on my EasyStar to the point of hitting 50 mph and overshootingthe runway, ending up in the trees.
Of course I can land in 500 feet easy, but making my autopilot do it wasnot. I was curious if anyone wanted to chime in on how they solvedtheir landing issues and minimizing the length of space required.
I was able to get mine down to 500 feet diving in from 200 feet and leveling off. The attached photo is my landing pattern.
1) Circle the landing zone, sample the winds
2) Go downwind
3) Turn for final approach
4) DIVE! with a feedback loop on airspeed able to do reverse thrust
5) flare and land.
My reverse thrust is done with a car speed controller. I can get +1 lbthrust as well as -1 lb of thrust. (Wasn't expecting that either.) Thisis just by running a typical 5x5 prop backwards!
The end result is that I slow down from 50 mph to 20 mph in a few seconds after the dive.
1) Limiting the reverse thrust to 50% of what it is now
2) Just cutting out the reverse thrust when I get within 50 feet of the ground
but yours sounds the best...
3) Scale maximum reverse thrust with elevator command.
I hope I can encourage others to try reverse thrust as a valid way to slow down in a hurry. It works reasonably well.
I can land my plane in the same space because I circle in and avoid the trees. I am trying to program the AP to do it in one step. Dive in and land.
All and all I think this technique works but has it's drawbacks.
Also, I purposefully descending too late. I am getting ready to land in my backyard, where I only have a few hundred feet and tall trees all around. I'm trying to practice :)
You are also right in controlling descent with throttle, but that requires more space. This was an experiment to see if I could do better by breaking all the rules.
Standard descent angle for most real real runways is about 3 degrees, which is 300ft/mile. So if you are 1 mile out from the touchdown point when turning final, you should be at 300ft, 1/2 mile final is 150ft, 1/4 mile final is 75 ft etc. Hope this helps.
You state that you have more success in low wind situations. Assuming that stability is not the issue, then I wonder if you are allowing for the "gradient effect". That is the reduction in airspeed as you get closer to the ground. I suspect that when you are flying it yourself, you are making automatic corrections for this. The autopilot is following some other rule.
And always remember - "There are three rules for a perfect landing every time . . . unfortunately, noone knows what they are."
This is how real airplanes are flown, so I assume it should work fine with the easystar as well.
Once mine can be trusted, I'll start doing landings and give you all the data.
1
2
3
4
of 4 Next
