YD6-1600L hexacopter frame is a multifunctional heavy-lift flight platform. Its one-time forming carbon fiber technology reduces weight while still keep the stiffness, which makes it stronger and lighter for long flight time.
Stable and reliable
YD6-1600L arm connector is using special compound material: industrial plastic with glass fiber. This compound material features high strength and flexibility, which can stand high-frequency vibration created by the motors in the air. Furthermore, with a glass fiber canopy, the GPS signal will not be blocked.
Easy for setup and maintenance
Frame arm of YD6-1600L is detachable, which will enable you to finish the drone setup in 5 minutes. Furthermore, if the arm is broken during a flight crash, you will just need to replace it with a new one, which will greatly save your maintenance cost and time.
Long flying time
Equipped with the 29inch propeller, KV85 U8 Lite motor, 2 units 6S 32000mah HV lipo battery, the YD6-1600L frame is able to fly 61 minutes with 2KG payload, 47 minutes with 5KG payload.
Good for drone customization
YD6-1600L comes with big size center frame, which is able to accommodate more devices. So it becomes an ideal flight platform for your drone customization.
Power combo it is using
Motor: T-Motor U8 Lite KV85 motor
ESC: T-Motor ALPHA 60A HV ESC
Propeller: T-Motor 29*8.7 inch propeller
Battery: 2 x Tattu 6S 32000mAh 22.8V high voltage lipo
Photos
3689738956?profile=original
3689738975?profile=original
3689738837?profile=original
3689738998?profile=original
3689738850?profile=original
3689738904?profile=original
